1990 Chevy Lumina Fuel pressure test
1990 CHEVROLET LUMINA
220,000 MILES • 6 CYL • FWD • AUTOMATIC
GOLFNGUITARS
  • 13 POSTS
I submitted a question several days ago. 1990 lumina hard to start cold or hot. Your response was to test the fuel pressure first, if that checks out, then change the ECT sensor, TPS, and the ingnition switch.
I tested the fuel pressure and not sure what to make of it. First I tested the fuel pump by applying 12 volts to the test terminal. All is well, I hear the whinning sound. Now connecting the gauge to the schrader valve, key in the on position, the pressure is low, 10 psi. I started the car, pressure jumped to specs, 32 psi. From there all checks out OK. I tapped the throttle, pressure jumps about 5psi. Removed the pressure regulator vacuum, pressure jumps about 10 psi. I did change the ECT, no effect on starting, however I believe the idle is improved and the exhaust smells better. I believe it was a little rich before.
I did notice when tapping the throttle, there is a very slight hesitation. Very slight!! What should I do at this point? Why is the fuel pressure low when the key is in the ON position?
Jul 29, 2010 at 5:32 PM
MERLIN2021
  • 17,250 POSTS
Pressure is tested with key on engine off and should read 41-47 psi for 3.1 and 40-47 3.8 So replace the fuel pump and you are good to go. You can check the filter, but I haven't come across one that clogged and still run! here it is from the book:
Fuel Pressure Check (PFI) 1. Relieve fuel pressure as previously described in FUEL PRESSURE RELIEF (PFI). Connect Fuel Pressure Gauge (J-34730-1) to fuel pressure fitting on fuel rail. 2. With gauge installed at fuel rail connector, turn ignition on. With ignition on and engine off, pressure should read within specification. See SPECIFICATIONS - 4-CYL article (for 4- cylinder models), See SPECIFICATIONS - V6 article (for V6 models),See SPECIFICATIONS - V8 article (for V8 models). Start engine. Pressure should drop 3-10 psi (.2-7 kg/cm 2 ). For more details on fuel system pressure testing, see SYSTEM/COMPONENT TESTS article.
Jul 29, 2010 at 5:41 PM
GOLFNGUITARS
  • 13 POSTS
[quote:550cd5c8ec="merlin2021"]Pressure is tested with key on engine off and should read 41-47 psi for 3.1 and 40-47 3.8 So replace the fuel pump and you are good to go. You can check the filter, but I haven't come across one that clogged and still run! here it is from the book:
Fuel Pressure Check (PFI) 1. Relieve fuel pressure as previously described in FUEL PRESSURE RELIEF (PFI). Connect Fuel Pressure Gauge (J-34730-1) to fuel pressure fitting on fuel rail. 2. With gauge installed at fuel rail connector, turn ignition on. With ignition on and engine off, pressure should read within specification. See SPECIFICATIONS - 4-CYL article (for 4- cylinder models), See SPECIFICATIONS - V6 article (for V6 models),See SPECIFICATIONS - V8 article (for V8 models). Start engine. Pressure should drop 3-10 psi (.2-7 kg/cm 2 ). For more details on fuel system pressure testing, see SYSTEM/COMPONENT TESTS article.[/quote:550cd5c8ec]
New Info!!!
I performed another fuel pressure test, this time when the key is in the on position, I am getting a reading of 42psi. However, the pressure drops to ZERO after a few seconds. So, I turned the key off, and on again, 42psi, so I started the car immediately, and the car started right up, with 34 psi while ideling. I perfomed this operation 6 times with the same result. Is the fuel pump weak, or perhaps an intermittent connection somewhere? The car runs and accelerates quite well!!
Jul 29, 2010 at 6:14 PM
MERLIN2021
  • 17,250 POSTS
No it's probably OK, this system is designed to bleed the pressure off quicker than most, as long as it's OK with key on engine off and drops 3-10 psi on start up, it's OK.
Jul 29, 2010 at 6:24 PM
GOLFNGUITARS
  • 13 POSTS
[quote:a5cb038697="merlin2021"]No it's probably OK, this system is designed to bleed the pressure off quicker than most, as long as it's OK with key on engine off and drops 3-10 psi on start up, it's OK.[/quote:a5cb038697]
This seems to be an intermittant problem. Sometimes when I turn the key to the ON position, I have 42psi, sometimes I have zero. What should I do from here? Could it be the TPS or MAP sensors? Could it be the wireing at the fuel pump relay? Or connecting harness near the fuel tank? I guess we have ruled out a faulty fuel pump? I was repaced 4 years ago. Thankyou for all your help.
Jul 29, 2010 at 6:40 PM
MERLIN2021
  • 17,250 POSTS
when it reads zero check for power at the pump, use a volt meter. the pump is designed to run only 2-3 seconds so hook up the meter and get a friend to turn the key on.
Jul 29, 2010 at 6:49 PM
GOLFNGUITARS
  • 13 POSTS
[quote:80259f3ad3="merlin2021"]when it reads zero check for power at the pump, use a volt meter. the pump is designed to run only 2-3 seconds so hook up the meter and get a friend to turn the key on.[/quote:80259f3ad3]
OK, you're going to have to instruct me on how to test for power at the pump. I have a multimeter, but where do I test?
Jul 29, 2010 at 6:59 PM
MERLIN2021
  • 17,250 POSTS
The pump is inside the gas tank, jack up and place on stands, then unplug the connector at the pump, test gray wire and ground, meaning black lead to ground red lead to gray wire, this gray wire comes from the pump relay. at least 10 volts minimum is what we want. and you should here the pump run for the 2-3 seconds.
Jul 29, 2010 at 7:11 PM
GOLFNGUITARS
  • 13 POSTS
[quote:3905c7854b="merlin2021"]when it reads zero check for power at the pump, use a volt meter. the pump is designed to run only 2-3 seconds so hook up the meter and get a friend to turn the key on.[/quote:3905c7854b]
I just realized, when the pressure reads zero, I can hear the pump whining for a few seconds, so I assume it is getting power. This is what I have observed so far, when the car sits for 15 minutes or more, I turn the key on, the pressure reads zero, and I can hear the pump. After several attempts turning the key to the on position, then off, wait 10 seconds, turn on and off, wait, then maybe the 3rd or 4th try, the pressure is 42psi, and all is well from there. This is the best way I can describe what is happening here. What would cause this?
Jul 29, 2010 at 7:16 PM
MERLIN2021
  • 17,250 POSTS
- Check the following items.  Check fuel pump relay. To do this, connect test light between fuel pump test terminal (terminal "G" of ALDL on most vehicles) and ground. Turn ignition on. Light should illuminate for 2 seconds. If not, see FUEL PUMP RELAY in SYSTEM/COMPONENT TESTS article. For location of fuel pump test connector, see COMPONENT LOCATIONS in the article SYSTEM/COMPONENT TESTS in this section.  Check for poor quality or water contaminated fuel.  Check that TPS is not sticking or binding.  Check EGR operation.  Check for a leaking injector. To do this on TBI systems, disconnect injector electrical connector at injector. Crank engine and watch for fuel leakage.  Check that resistance of coolant sensor circuit or coolant sensor is not too high. See CODE 15 chart in appropriate TESTS W/CODES article in this section, or the SENSOR RANGE CHARTS article in this section.  Check ignition system for a worn distributor shaft, bare or shorted wires, incorrect pick-up coil resistance, loose ignition coil ground or moisture in distributor cap. Check for adequate spark using Spark Tester (ST-125).  Check for shorts by spraying plug wires with fine mist of water.  Remove spark plugs and check for wet plugs, cracks, improper gap, burned electrodes or heavy carbon deposits.  Check for correct fuel pressure in all speed ranges.  A faulty in-tank fuel pump check valve will allow fuel in lines to drain back to tank after engine is stopped. To check this condition, turn ignition off, disconnect fuel pressure line at fuel rail, remove filler cap, and connect a radiator test pump and apply 15 psi (1.0 kg/cm 2 ) pressure. If pressure will hold for 60 seconds, check valve is okay.  Check that PROM/MEM-CAL in vehicle is correct for that vehicle. Check with dealer for latest application information.  Check for restricted exhaust system.
See you in the am, early riser, so early to bed, 8:30 in my location 1 1/2 hour past bedtime!
Jul 29, 2010 at 7:32 PM
GOLFNGUITARS
  • 13 POSTS
[quote:566916169d="merlin2021"]- Check the following items.  Check fuel pump relay. To do this, connect test light between fuel pump test terminal (terminal "G" of ALDL on most vehicles) and ground. Turn ignition on. Light should illuminate for 2 seconds. If not, see FUEL PUMP RELAY in SYSTEM/COMPONENT TESTS article. For location of fuel pump test connector, see COMPONENT LOCATIONS in the article SYSTEM/COMPONENT TESTS in this section.  Check for poor quality or water contaminated fuel.  Check that TPS is not sticking or binding.  Check EGR operation.  Check for a leaking injector. To do this on TBI systems, disconnect injector electrical connector at injector. Crank engine and watch for fuel leakage.  Check that resistance of coolant sensor circuit or coolant sensor is not too high. See CODE 15 chart in appropriate TESTS W/CODES article in this section, or the SENSOR RANGE CHARTS article in this section.  Check ignition system for a worn distributor shaft, bare or shorted wires, incorrect pick-up coil resistance, loose ignition coil ground or moisture in distributor cap. Check for adequate spark using Spark Tester (ST-125).  Check for shorts by spraying plug wires with fine mist of water.  Remove spark plugs and check for wet plugs, cracks, improper gap, burned electrodes or heavy carbon deposits.  Check for correct fuel pressure in all speed ranges.  A faulty in-tank fuel pump check valve will allow fuel in lines to drain back to tank after engine is stopped. To check this condition, turn ignition off, disconnect fuel pressure line at fuel rail, remove filler cap, and connect a radiator test pump and apply 15 psi (1.0 kg/cm 2 ) pressure. If pressure will hold for 60 seconds, check valve is okay.  Check that PROM/MEM-CAL in vehicle is correct for that vehicle. Check with dealer for latest application information.  Check for restricted exhaust system.
See you in the am, early riser, so early to bed, 8:30 in my location 1 1/2 hour past bedtime![/quote:566916169d]
WOW!!! That's a long list of stuff to check. One thing caught my attention, you said check for restricted exhaust flow. This problem started the same day I got a new pipe and muffler installed. Do you think the muffler is bad, or worse, someone at the muffler shop tampered with my vehicle to cause this problem? Would that be possible?
Jul 29, 2010 at 7:44 PM
MERLIN2021
  • 17,250 POSTS
well look for any kinked or crushed pipes and rap on the converter and pipes, if the converter broke up inside and pieces got wedged in pipes of the muffler, it cause it. The other thing is, your fuel pump should slowly leak down from 42, it should not happen as fast as it seems to on yours, the pump could be jamming and un jamming. Test for exhaust blockage with a vacuum gauge, hook it up to manifold vacuum, raise idle to 2000 rpm, the gauge should hold steady over 15hg, if it falls, the exhaust is blocked. My money is on the fuel pump, but you never know!
Jul 30, 2010 at 6:50 AM
GOLFNGUITARS
  • 13 POSTS
[quote:74d6c590cd="golfnguitars"][quote:74d6c590cd="merlin2021"]- Check the following items.  Check fuel pump relay. To do this, connect test light between fuel pump test terminal (terminal "G" of ALDL on most vehicles) and ground. Turn ignition on. Light should illuminate for 2 seconds. If not, see FUEL PUMP RELAY in SYSTEM/COMPONENT TESTS article. For location of fuel pump test connector, see COMPONENT LOCATIONS in the article SYSTEM/COMPONENT TESTS in this section.  Check for poor quality or water contaminated fuel.  Check that TPS is not sticking or binding.  Check EGR operation.  Check for a leaking injector. To do this on TBI systems, disconnect injector electrical connector at injector. Crank engine and watch for fuel leakage.  Check that resistance of coolant sensor circuit or coolant sensor is not too high. See CODE 15 chart in appropriate TESTS W/CODES article in this section, or the SENSOR RANGE CHARTS article in this section.  Check ignition system for a worn distributor shaft, bare or shorted wires, incorrect pick-up coil resistance, loose ignition coil ground or moisture in distributor cap. Check for adequate spark using Spark Tester (ST-125).  Check for shorts by spraying plug wires with fine mist of water.  Remove spark plugs and check for wet plugs, cracks, improper gap, burned electrodes or heavy carbon deposits.  Check for correct fuel pressure in all speed ranges.  A faulty in-tank fuel pump check valve will allow fuel in lines to drain back to tank after engine is stopped. To check this condition, turn ignition off, disconnect fuel pressure line at fuel rail, remove filler cap, and connect a radiator test pump and apply 15 psi (1.0 kg/cm 2 ) pressure. If pressure will hold for 60 seconds, check valve is okay.  Check that PROM/MEM-CAL in vehicle is correct for that vehicle. Check with dealer for latest application information.  Check for restricted exhaust system.
See you in the am, early riser, so early to bed, 8:30 in my location 1 1/2 hour past bedtime![/quote:74d6c590cd]
WOW!!! That's a long list of stuff to check. One thing caught my attention, you said check for restricted exhaust flow. This problem started the same day I got a new pipe and muffler installed. Do you think the muffler is bad, or worse, someone at the muffler shop tampered with my vehicle to cause this problem? Would that be possible?[/quote:74d6c590cd]
I've been driving the car for several days now with no change to the symptoms. Based on all the information you gave me, I believe it is the fuel pump check valve sticking open causing the fuel to drain back into the tank. I have not tested this yet, but will try to do so soon. Every once in a while, the check valve must close because the fuel pressure will hold at 42psi after turning the car off. Does the check valve operate mechanically, or electrically? Just FYI, I installed new TPS and MAP sensors, the car runs even better now, but no effect on the fuel pressure problem which leads me to believe it is the fuel pump check valve. Before I test this, would anything else cause the fuel pressure to drop so quickly? Woud a bad fuel pressure regulator or leaking injectors cause the fuel pressure to drop so quickly after the car is shut off?
Aug 2, 2010 at 9:38 AM
MERLIN2021
  • 17,250 POSTS
All of the above! Check the injectors resistance they should be 12.0-12.4 ohms If one is bad it can wreak havoc in many problems, from stalling when hot to no starts. Fuel pressure regulator on PFI Port injected, (injector for each cylinder) has a vacuum operated regulator, if any gas is in the vacuum hose, replace it, if the fuel pressure should drop 4-7 psi with the vacuum hose attached to the regulator, than with it disconnected, also check for vacuum at the line. If you still loose pressure fast, replace the pump.
INJECTOR BALANCE TEST The injector balance test is used to pulse the injector for a precise amount of time, spraying a measured amount of fuel in the intake manifold. As each injector is pulsed, a drop in fuel rail pressure occurs. This pressure drop can be recorded and compared to other injectors. An injector with a pressure drop of 1.5 psi (.11 kg/cm 2 ) or more, greater than or less than other injectors, should be considered faulty. 1. With ignition off, connect Fuel Pressure Gauge (J-34730-1) to pressure tap. Unplug harness connector at all injectors. Connect Injector Tester (J-34730-3) to one of the injectors. 2. Follow manufacturer's instructions when installing adapter harness. Ignition should be turned off at least 10 seconds to complete ECM shutdown cycle. 3. Turn ignition on. Fuel pump should run at least 2 seconds after ignition is turned on. Bleed air from gauge and hose to ensure accurate gauge reading. Repeat this procedure until all air is bled from system. Turn ignition off for at least 10 seconds. 4. Turn ignition on again to bring fuel pressure to maximum. Record initial pressure reading. Energize tester one time and note pressure drop at lowest point. 5. Disregard any slight pressure drop after low point is reached. Subtracting second pressure reading from initial reading indicates amount of injector pressure drop. 6. Repeat step 4) on each injector and compare pressure drop. Recheck injectors not within pressure drop range. Replace injector(s) failing second check. 7. If injectors are all okay, plug in harness connectors and review SYMPTOMS in H - TESTING W/O CODES article. NOTE: Allow engine to cool down to avoid irregular readings due to "Hot Soak" fuel boiling. To prevent flooding, the INJECTOR BALANCE TEST should not be repeated more than once without starting and running engine. CAUTION: To avoid possible vehicle fire, wrap a shop towel around fitting to avoid fuel spillage.
Aug 2, 2010 at 1:01 PM
