1998 Chevy Lumina instrument panel light was gone
1998 CHEVROLET LUMINA
200,000 MILES • 6 CYL • FWD • AUTOMATIC
XJSHEN
  • 245 POSTS
My 1998 lumina' instrument panel lights were gone while other warning light were ok. I removed the cluster and checked the 4 bulbs in the cluster those were ok. I detected votage on the fuse 1, (instrument panel adn console cigar lighters), and foud there was no voltage on the fuse 1.
what could be problem how to fix it?
Thanks for your help!!!
Xiang
Jul 21, 2010 at 12:09 AM
DAVE H
  • 13,384 POSTS
Hello .. thanks for the donation .. much appreciated Check fuses #39, #25 and #4 ..in the fuse block on right side of dashboard .. fuse #39 is the main fuse to the dashboard !
https://www.2carpros.com/forum/automotive_pictures/266999_lum_1.jpg
Hope this helps
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_1181.png
Jul 21, 2010 at 3:12 AM
XJSHEN
  • 245 POSTS
Thanks for your reply. Actually I checked and cleaned all fuse and replaced with new fuses in the fuse box including #39, #25, #4.
I replaced melted fuse #16 for Horn and fixed horn problem last time.
Thanks for further commennt and help!
xiang
Jul 21, 2010 at 6:46 AM
XJSHEN
  • 245 POSTS
Thanks Dave!
I found that there was no Fuse insert in the #25 fuse panel (this location was empty). in the Car Manual there is #25 location. I do not know how it disapeared. How can add insert plug into this location ? Is it possible cause for instrument panel lights gone? Thanks for further comment and help!
Jul 21, 2010 at 7:11 AM
DAVE H
  • 13,384 POSTS
Thanks for the Feedback !!
You will not have a fuse #25 if you do not have SEO fitted to the vehicle
Some models are equipped with Special Equipment Option (SEO) instrument cluster, which uses a digital speedometer module in addition to the gauges and warning indicators available on the standard cluster. The digital speedometer module receives ignition voltage, ground and Vehicle Speed Sensor (VSS) signal independent of instrument cluster connector. Digital speedometer and radio can be step dimmed to a night mode when headlight switch is activated.
SOME OR ALL INSTRUMENT CLUSTER ILLUMINATION LIGHTS INOPERATIVE
Operate turn signals. If turn signal indicator lights illuminate properly, go to next step. If turn signal indicator lights do not illuminate properly, go to step 6).
Set headlight switch in PARK position. Set instrument panel dimmer switch to maximum brightness. If A/C-heater control illumination lights illuminate, go to next step. If A/C-heater control illumination lights do not illuminate, locate and repair problem in interior light dimming system. See WIRING DIAGRAMS .
Turn headlight switch off. Disconnect instrument cluster Black 32-pin connector. Set headlight switch in PARK position. Set instrument panel dimmer switch to maximum brightness. Using DVOM, check voltage between instrument cluster harness connector terminal C5 (Gray wire) and ground. Check voltage between instrument cluster harness connector terminal C6 (Gray wire) and ground. If reading is 9-14 volts for both terminals, go to next step. If reading is not 9-14 volts for both terminals, go to step 5).
Check illumination bulb(s) and bulb connection. Repair as necessary and recheck system operation. If bulbs and bulb connection are okay, replace instrument cluster. See INSTRUMENT CLUSTER under REMOVAL & INSTALLATION. Recheck system operation.
Repair poor connection or open in appropriate circuit No. 8 (Gray wire) between instrument cluster and splice S203 (located in instrument panel wiring harness behind instrument cluster, about 2" from instrument cluster breakout). Recheck system operation.
Check for poor connection in circuit No. 150 (Black wire) between instrument cluster and ground. Repair as necessary and recheck system operation. If circuit is okay, replace instrument cluster. See INSTRUMENT CLUSTER under REMOVAL & INSTALLATION. Recheck system operation.
Jul 22, 2010 at 4:54 AM
XJSHEN
  • 245 POSTS
Thanks Dave. That is right. You are outstading expert in this area!!! I trust you.
It is intoo profasional manner I even do not konw what is that and where are C5, C6, C8, S203, and circuit No. 150 located that you mentioned in your email.
Can you kinedly sent me a schametic chart, pictures that showing the location and the order in the switch pleas? Actually I disconected all Dash instrument panel plate. But there were so many lines connect to the inserts, so, I do not know whre is switch and what is these terminal.
Thanks for your further help!!!
Jul 22, 2010 at 9:22 AM
DAVE H
  • 13,384 POSTS
the connectors are located on rear of instrument cluster !
https://www.2carpros.com/forum/automotive_pictures/266999_lum_2.jpg
https://www.2carpros.com/forum/automotive_pictures/266999_lum2_1.jpg
Jul 23, 2010 at 4:48 AM
XJSHEN
  • 245 POSTS
Hi Dear Dave,
thanks! this time is much better! I will figure out the problem.
Again thanks!
Jul 23, 2010 at 1:09 PM
DAVE H
  • 13,384 POSTS
Not a problem .. thanks for using 2carpros ..
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_1186.png
Aug 2, 2010 at 3:13 AM
