History:
I'm the Original owner. Only major problem was a leaky lower intake manifold gasket, which was fixed. About a year and 1/2 ago, car would have trouble keeping idle on warm days. I would leave for work in morning and it would drive fine. Upon leaving work on days warmer than about 70 degrees, the car would start, but would fight to stay idle. As i drove it, it would chug along and about 10 minutes later would finally smooth out and be ok. Last fall, it finally took a dump and would not start at all. I had to trailer it to my new home and it sat all winter until now. I just replaced the Mass air flow sensor, cuz it was not working, and I replaced the plugs. I tested the fuel pump and i'm getting great fuel pressure. The wires are newer, air filter is good, and the engine is getting plenty of spark. It just wont start. The engine will crank but not start. When it was running just before it died, I took it to Autozone for a Check Engine Light diagnosis and it came back with the speed input sensor and the EGR valve. Could any one of these contribute to the car not starting now? Thank you for any help you can provide on this. I'm at my whits end on this one.
Aug 7, 2007 at 9:27 AM
