2003 Chevy Malibu hesitates on hills
2003 CHEVROLET MALIBU
170,000 MILES • 6 CYL • FWD • AUTOMATIC
KJMCQUEE
  • 7 POSTS
I lose power going up hills and accelerating, but I am getting 29mpg out of the 3.1 malibu. After a 30min drive it smells really hot mostly around the fuse box area in general. Turn signals stop working sometimes. Checked the egr with a 9v and was working properly, Cat and O2 sensors are new, Coil packs new, plug wires and plugs have about 15,000 miles on them, intake gaskets replaced, throttle body cleaned, MAF cleaned with MAF cleaner, throttle position sensor new, thermostat about 15,000miles, was overheating before replacing cat. Oh and I replaced the trans filter, no flush from dealer. I am banging my head when I hit a hill. I need to forget about it, but I don't have anymore money to put towards this. Any testing I could do to check MAF or any other sensor.
Feb 22, 2010 at 11:52 AM
SCOTTY DEE
  • 592 POSTS
Hi kjmcquee! Are there any codes stored in memory?
Feb 22, 2010 at 5:52 PM
KJMCQUEE
  • 7 POSTS
1 code for egr because I unplugged it to check, not sure how to clear codes. Will unplugging battery do it?
Feb 23, 2010 at 6:11 AM
SCOTTY DEE
  • 592 POSTS
The codes have to be reset with a code reader/scan tool. Plug the EGR back in and drive it. Have ALL codes retrieved and write the code numbers down. Let me know what you come up with.
Feb 23, 2010 at 8:11 AM
KJMCQUEE
  • 7 POSTS
no codes, starting to feel the car shake a little at high speeds, not the tires just was aligned and balanced and shaking isn't in the steering wheel. Also after I floor it turnsignals don't want to work until I hit the flasher button to maybe reset it. I don't know, but I feel it is electrical or vacuum related. I changed the fuel filter last year and my wife puts about 25000miles on the car a year. Can the fuel filter go bad that quick
Feb 24, 2010 at 11:41 AM
SCOTTY DEE
  • 592 POSTS
Fuel filters are good for 15K-25K. Not sure about the WOT and the turn signals not working. You may be on the right path with electrical issues. I think there may be a couple of things going on at the same time.
Without any codes we can assume that fuel pressure may be a reason. I would want to attach a fuel pressure gauge to the windsheild and drive it to verify.
Feb 25, 2010 at 6:08 PM
