2000 Chevy Monte Carlo How to change spark plugs and wires
2000 CHEVROLET MONTE CARLO
80,000 MILES • 6 CYL • FWD • AUTOMATIC
FOX WOOD
I have a 2000 Monte Carlo Pace Car with a 3800 (3.8) SFI turbocharged V6 engine and automatic transmission.
Please tell me the best procedure for changing the spark plugs and spark plug wires.
Thank you!
Fox.[img:9024ea3b80]http://www.2carpros.com/forum/automotive_pictures/455150_monte1_1.jpg[/img:9024ea3b80]
Dec 29, 2009 at 8:57 AM
RACEFAN966
  • 5,029 POSTS
Well first find the coil pack, it is either on a braket on top of the engine or on the side of the engine, follow the a spark plug wire to it. Now remove one wire and that plug then replace that wire and plug. If you do this one at a time then you don't need to remember the firing order. Here is the firing order for the 3.0 ltr. Now if you include a pic of the top side of the engine I will see if there is anything else to remove to gain access. Here is the firing order.
https://www.2carpros.com/forum/automotive_pictures/249564_Graphic_173.jpg
Dec 29, 2009 at 10:23 AM
