What voltage do you have at the battery?
(a good battery has 12.6v).
How old is your battery? (avg battery life: 4-5 years)
Also, if you recharge the battery, test it to see if it holds a charge.
Once you jump start the car and the engine is running, what's the voltage at the battery? if you have under 13.5v, there's somethig wrong in your charging system. Get your alternator bench tested at an autopart store.
You could have a parasitic drain on your battery but 10 minutes sounds short for the battery to die.
Jun 6, 2020 at 12:21 PM
(Merged)
