recently my brake pedal travel has increased, requiring more foot pressure to stop truck. I come to a light, for example and stop, after I stop, then I need to push brake pedal down more because truck starts to creep and roll.
I have inspected asll four wheels for fluid leaks.
I have completely flushed old brake fluid.
I have bled the entire brake system.
And I have replaced master cylinder.
The problem still exists. I have purchased and received a new ABS pump module but have not installed it yet.
I have also visibly checked vacuum boost lines for leaks and could not see a problem.
Any ideas??
Also The brake fluid level does not go down (no fluid leaks)
Thank you very much, Jens Moyer
Any ideas??
Mar 21, 2009 at 1:53 PM
