1994 Chevy Silverado harmonic balancer
1994 CHEVROLET SILVERADO
ADAM1375
Engine Mechanical problem
1994 Chevy Silverado V8 Four Wheel Drive Automatic
How to change a harmonic balancer on a 1994 k1500 4wd 5.7L Engine?
Sep 18, 2010 at 12:05 AM
You will need to remove the belt, pulley that is attached to the balancer, remove the center bolt that connects the balancer to the crank, and then with a wheel puller, remove the harmonic balancer. It will have a keyway so make sure when you replace it, you line it up.
Sep 18, 2010 at 11:29 PM
