You will first have to remove the door panel be very careful that you don't break anything, there will be many hidden screw, so stay alert, once the door panel has been removed depending upon the position of your window if it's down or up, you will have to unbolt window frame from the regulator, take it all the way to the top and use some duct tape to hold it in place, you will then locate the bolts that are holding the regulator in remove them bolts and the regulators should come out, keep in mind that there may be rivets also, you will have to drill them out, just make sure you use a small punch and nock the center out before grilling.
May 30, 2019 at 2:15 PM
(Merged)
