1995 Chevy Suburban How do i do the Paperclip test on a 95
1995 CHEVROLET SUBURBAN
139,000 MILES • V8 • 4WD • AUTOMATIC
BIGTIMETRUCK
  • 9 POSTS
When I crank the car the airbag light flashes, then goes out so i want to find the code, to find the fault in the unit.
Oct 21, 2010 at 9:53 AM
DOCFIXIT
  • 18,828 POSTS
Hi If SIR is operating properly light will flash 7-9 times on start up. Need a scanner to read SIR codes. Can access PCM codes 12 pin jumper from A-B
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_659.jpg
16 pin jumper from pin 5-6
https://www.2carpros.com/forum/automotive_pictures/198357_Grafic_3_159.jpg
Hope this helps Thanks for donate
Oct 21, 2010 at 10:06 AM
