1999 Chevy Suburban Oxygen sensor and evaporative purge sol
1999 CHEVROLET SUBURBAN
156,000 MILES • V8 • 2WD • AUTOMATIC
TECLIETT
Can you tell me where both of these are located and how to replace them? Both are supposedly bad and are causing to fail the inspection test. Thank you.
Aug 29, 2009 at 1:20 PM
MXCANICHOLS
Which oxygen sensor? There are 4 Heated o2 sensors on the exhaust pipe. Bank 1 sensor 1 left side just below exh manifold to pipe connection, bank 2 sensor 1 r side same location, Bank 2 sensor 2 r side just aft of catalytic converter, bank 1 sensor 2 same location on left side. The Heated Oxygen Sensors are mounted in the exhaust system where they can monitor the oxygen content of the exhaust gas stream. The oxygen present in the exhaust gas reacts with the sensor to produce a voltage output. This voltage should constantly fluctuate from approximately 100 mV (high oxygen content - lean mixture) to 900 mV (low oxygen content - rich mixture). The heated oxygen sensor voltage can be monitored with a scan tool. By monitoring the voltage output of the oxygen sensor, the PCM calculates what fuel mixture command to give to the injectors (lean mixture - low HO2S voltage = rich command, rich mixture - high HO2S voltage = lean command). When the VCM detects a malfunction in the HO2S heater circuits, the following DTCs will set: "¢DTC P0135 Bank 1 Sensor 1 heater. "¢DTC P0155 Bank 2 Sensor 1 heater. "¢DTC P0141 Bank 1 Sensor 2 heater. "¢DTC P0161 Bank 2 Sensor 2 heater. When the VCM detects no HO2S activity, the VCM will set the following DTCs: "¢DTC P0134 Bank 1 Sensor 1. "¢DTC P0154 Bank 2 Sensor 1. "¢DTC P0140 Bank 1 Sensor 2. "¢DTC P0160 Bank 2 Sensor 2. When the VCM detects an HO2S signal circuit that is high, the VCM will set the following DTCs: DTC P0132 Bank 1 Sensor 1. "¢DTC P0152 Bank 2 Sensor 1. "¢DTC P0138 Bank 1 Sensor 2. "¢DTC P0158 Bank 2 Sensor 2. When the VCM detects an HO2S signal circuit that is low, the VCM will set the following DTCs: "¢DTC P0131 Bank 1 Sensor 1. "¢DTC P0151 Bank 2 Sensor 1. "¢DTC P0137 Bank 1 Sensor 2. "¢DTC P0157 Bank 2 Sensor 2.
https://www.2carpros.com/forum/automotive_pictures/404531_Heated_o2_sensor_1.jpg
CAUTION : The Heated Oxygen Sensor (HO2S) and the Oxygen Sensor use a permanently attached pigtail and connector. Do not remove this pigtail from the Heated Oxygen Sensor. Damage or the removal of the pigtail or the connector could affect the proper operation of the sensor. CAUTION : Take care when handling the HO2S. Keep the in-line electrical connector and the louvered end free of grease, dirt, or other contaminants. Also avoid using cleaning solvents of any type. Do not drop or roughly handle the HO2S. CAUTION : If the heated oxygen sensor pigtail wiring, connector or terminal is damaged, the entire oxygen sensor assembly must be replaced. Do Not attempt to repair the wiring, connector or terminals. In order for the sensor to function properly, it must have provided to it a clean air reference. CAUTION : This clean air reference is obtained by way of the oxygen sensor signal and heater wires. Any attempt to repair the wires, connectors, or terminals could result in the obstruction of the air reference and degraded sensor performance. The following guidelines should be used when servicing the heated oxygen sensor: "¢Do Not apply contact cleaner or other materials to the sensor or vehicle harness connectors. These materials may get into the sensor causing poor performance. "¢The sensor pigtail and harness wires must not be damaged in such a way that the wires inside are exposed. This could provide a path for foreign materials to enter the sensor and cause performance problems, "¢Neither the sensor or vehicle lead wires should be bent sharply or kinked. Sharp bends, kinks, etc., could block the reference air path through the lead wire. "¢Do Not remove or defeat the oxygen sensor ground wire (where applicable). Vehicles that utilize the ground wired sensor may rely on this ground as the only ground contact to the sensor. Removal of the ground wire will cause poor engine performance. "¢To prevent damage due to water intrusion. be sure that the peripheral seal remains intact on the vehicle harness connector. The engine harness may be repaired using Packard's Crimp and Splice Seals Terminal Repair Kit. Under no circumstances should repairs be soldered since this could result in the air reference being obstructed. CAUTION : The Heated Oxygen Sensor (HO2S) may be difficult to remove when the engine temperature is below 48 °C (120 °F). Excessive force may damage the threads in the exhaust manifold or the exhaust pipe. REMOVAL PROCEDURE 1.Disconnect the negative battery cable. 2.Remove the electrical connector by releasing the locking tab. 3.Carefully back out the heated oxygen sensor. INSTALLATION PROCEDURE NOTE : A special anti-seize compound is used on the Heated Oxygen Sensor (HO2S) threads. The compound consists of liquid graphite and glass beads. The graphite tends to burn away, but the glass beads remain, making the sensor easier to remove. New, or service replacement sensors already have the compound applied to the threads. If the sensor is removed from an engine and if for any reason it is to be reinstalled, the threads must have anti-seize compound applied before the reinstallation. 1.Coat the threads of the oxygen sensor with anti-seize compound GM P/N 5613695 or the equivalent if necessary. 2.Install the sensor. Tighten "¢Tighten the sensor to 41 Nm (30 lb. ft.) . 3.Install the electrical connector. 4.Connect the negative battery cable.
Sep 3, 2009 at 9:45 AM
MXCANICHOLS
Loaction on r side of intake manifold looking forward, just forward of igniton coil area. Look for black plastic hose connecting to it. Two vertical mounting bolts. I believe 10mm. One electrical plug on top. Disconect plug, remove nut from mounting stud, disconnect hose, lift out of intake manifold.
https://www.2carpros.com/forum/automotive_pictures/404531_Evap_sol_1.jpg
Sep 3, 2009 at 9:59 AM
JESSICA BENTON
Looking for the location of all the O2 sensors and where they plug into.
Feb 7, 2019 at 7:23 PM (Merged)
Good evening,
I attached a picture of the location of the sensors.The connectors are usually within about a foot of the sensor
What is your exact issue as these do not fail that often?
DALEFIN
where is o2 sensor bank1 sensor1 located?
BLACKOP555
  • 10,386 POSTS
driver side exhaust BEFORE the catalytic convertor.
try running the engine till its hot before removing it, dont get burned.
CBCROCKER
  • 4 POSTS
I just got the P0430 code and have been reading up on it. The first thing they say to do is check the voltage at the O2 sensors. No problem with that but I can't find anything stating what the readings should be. Also, is there a way to tell if it's the pre-cat or post-cat sensors?
DOCFIXIT
  • 18,828 POSTS
Bank 1 past CAT voltage .02-1V at idle. Lean .1v rich.9V
YOLIE0622
Check engine light is on. Used my OBD2 meter & codes 140 & 137 came up. I changed all sensors, cat convert, transmission, & transfer case has been recently changed. Check engine still on. There was a wire lose going to the oxygen sensors & I had it repaired. Check engine light still on with the same codes. What else can it be?
KHLOW2008
  • 41,814 POSTS
Hi yolie0622,
thank you for the donation.
Is your vehicle a C or K body model?
YOLIE0622
K1500, 8cyl.
KHLOW2008
  • 41,814 POSTS
If after replacement of sensors and the problem recurrs, the next thing to do would be to check the wirings. Here are the diagnostic procedures.
DTC P0137: HO2S CIRCUIT-LOW VOLTAGE-BANK 1, SENSOR 2 (4.8L, 5.3L & 6.0L "C" & "K" SERIES & 5.7L "F" & "Y" BODIES)
Circuit Description
PCM supplies about 450 millivolts (mV) between HO2S high and low signal circuits. The HO2S voltage ranges from about 1000 mV when exhaust is rich to about 10 mV when exhaust is lean. PCM monitors and stores sensor voltage information and evaluates voltage samples to determine amount of time sensor voltage is out of range. If PCM detects HO2S voltage is less than predetermined voltage, DTC P0137 will set.
For duplication of DTC, ensure:
• DTCs P0101, P0102, P0103, P0112, P0113, P0117, P0118, P0121, P0122, P0123, P0125, P0200, P0335, P0336, P0351-P0358 or P1258 are not set.
• AIR, EGR and catalyst diagnostics not active.
• Ignition voltage is greater than 9 volts.
• Fuel system is operating in "closed loop".
• Fuel trim learn is enabled.
• TP sensor angle is between 2 and 70 percent.
Diagnostic Procedures
1. Perform On-Board Diagnostic (OBD) system check.
After performing OBD system check, go to next
step.
2. Start and warm engine to normal operating temperature. Operate vehicle under conditions equired to set DTC. Using scan tool, select ENGINE 1 DATA LIST and monitor HO2S voltage. If HO2S 2 voltage is fixed less than 80 mV, go to step 4. If HO2S voltage is not fixed less than 80 mV, go to next step.
3. Turn ignition on, with engine off. Using scan tool, review FREEZE FRAME and/or FAILURE RECORDS data and note parameters. Turn ignition off for about 15 seconds. Start engine and operate vehicle within conditions required for this diagnostic to run, and as
close to conditions recorded in FREEZE FRAME/FAILURE RECORDS as possible. Select DTC function, and then enter DTC P0137. If scan tool indicates that this test failed this ignition, go to next step. If scan tool does not indicate that this test failed this ignition, see DIAGNOSTIC AIDS.
4. Disconnect HO2S 2 connector. Connect a fused jumper wire between PCM connector (harness side), HO2S 2 low circuit and ground. If sensor voltage is 350-550 mV, see DIAGNOSTIC AIDS. If sensor voltage is not 350-550 mV, go to next step.
5. Turn ignition off. Disconnect PCM harness connector C1. Check HO2S 2 signal circuit for short to ground or short to sensor ground circuit. Repair as necessary. After repairs, go to next step. If circuit(s) are okay, go to step 7.
6. Repair HO2S 2 signal circuit. After repairs, go to step 8.
7. Replace PCM. Program replacement PCM using required equipment. After repairs, go to next step.
8. Using scan tool, clear DTCs. Start and warm engine to normal operating temperature. Select
DTC, SPECIFIC, and then enter DTC P0137. Operate vehicle within conditions for setting this DTC. If scan tool indicates that this test ran and passed, go to next step. If scan tool does not indicate that this test ran and passed, go to step 2.
9. Using scan tool, select CAPTURE INFO, REVIEW INFO function. If any undiagnosed DTCs are displayed, go to applicable DTC test. If no undiagnosed DTCs are displayed, system is okay.
Diagnostic Aids
Check HO2S pigtail wire for breaks, contamination or grounding on exhaust manifold. Check for intermittent ground in signal wire between sensor connector and sensor.
Check for lean injector(s). Perform injector balance test. See appropriate SYSTEM & COMPONENT TESTING article. Check for fuel contamination, improper fuel pressure or exhaust leak, especially near HO2S. Check for vacuum or crankcase leak, causing a lean condition.
DTC P0140: HO2S CIRCUIT-INSUFFICIENT ACTIVITY-BANK 1, SENSOR 2 (4.3L, 5.0L, 5.7L & 7.4L "C", "G", "K" & "P" SERIES)
Circuit Description
VCM supplies a voltage of about .45 volt between HO2S 2 signal and HO2S 2 ground circuits. HO2S 2 varies voltage from about one volt with rich exhaust to .1 volt with lean exhaust. HO2S 2 produces no voltage and acts as an open circuit when temperature is less than 600°F (316°C). An open sensor circuit or a cold sensor causes open loop operation.
HO2S 2 heater provides for faster sensor warm-up allowing sensor to become active in a shorter period of time and remain active during long extended idle. DTC determines if HO2S 2 or HO2S 2 circuit is open. DTC P0140 will set if VCM fails to detect minimum number of HO2S 2 voltage transitions greater than and less than bias voltage range of 300-600 mV.
• No active EVAP system, misfire, TP, IAT, MAP, ECT or MAF sensor DTCs are set.
• No intrusive tests are in progress.
• No device controls are active.
• System voltage is 11.7-18 volts.
• Engine run time is greater than 2 minutes.
• Decel fuel cut-off mode is not active.
• ECT is 137°F (58.5°C) or greater.
• MAF is 13 grams per second.
• System is in closed loop.
1. Perform On-Board Diagnostic (OBD) system check. After performing OBD system check, go to next
step.
2. Using scan tool, store DTC information from VCM. Clear DTCs and reset fuel trim values. Start engine and allow it to reach normal operating temperature. Monitor HO2S 2 voltage on scan tool. If voltage is fixed at 400-473 mV, go to step 4. If voltage is not as specified, go to next step.
3. Condition that set DTC is not present at this time. If any additional DTCs are set, go to applicable DTC test. If no additional DTCs are set, see DIAGNOSTIC AIDS.
4. Turn ignition off. Disconnect HO2S 2 harness connector. Using jumper wires, jumper HO2S 2 high and low signal circuits to ground. Turn ignition on. Monitor HO2S 2 voltage with scan tool. If voltage is less than 20 mV, go to step 7. If voltage is not less than 20 mV, go to next step.
5. Turn ignition off. Remove jumper wires. Disconnect VCM harness connector containing HO2S 2 circuits. Measure resistance of HO2S 2 high and low signal circuits between HO2S 2 and VCM. If resistance of both circuits is less than 5 ohms, go to next step. If resistance of either circuit is not less than 5 ohms, go to step 9.
6. Check VCM harness connections. Repair as necessary. After repairs, go to step 17. If connections are okay, go to step 16.
7. Remove jumper wires from HO2S 2. Turn ignition on. Connect test light between HO2S 2 heater ignition feed and ground circuits at HO2S 2 harness connector. If test light illuminates, go to next step. If test light does not illuminate, go to step 10.
8. Turn ignition off. Reconnect HO2S 2 harness connector. Disconnect VCM harness connector containing HO2S 2 low signal circuit and VCM harness connector containing VCM ground circuits. Measure resistance between HO2S 2 low signal circuit and one of the VCM ground circuit terminals at VCM harness connector. If resistance is less than 500
ohms, go to step 12. If resistance is not less than 500 ohms, go to step 11.
9. Repair circuit with high resistance. After repairs, go to step 17.
10. Repair HO2S 2 heater ignition feed or ground circuit. After repairs, go to step 17.
11. Repair high resistance between HO2S 2 low signal circuit and VCM ground circuit. After repairs, go to step 17.
12. Check for exhaust leaks upstream of HO2S 2. Repair as necessary. After repairs, go to step 17. If no leaks are found, go to next step.
13. Allow engine to completely cool. Measure resistance between HO2S 2 low signal circuit and one of the VCM ground circuit terminals at VCM harness connector. If resistance is less than 500 ohms, go to step 15. If resistance is not less than 500 ohms, go to next step.
14. Remove HO2S 2. Clean threads and apply anti-seize compound, and then reinstall. Measure resistance between HO2S 2 low signal circuit and one of the VCM ground circuit terminals at VCM harness connector. If resistance is less than 500 ohms, go to step 17. If resistance is not less than 500 ohms, go to next step.
15. Replace HO2S 2. After repairs, go to step 17.
16. Replace VCM. Program replacement VCM using required equipment. Perform Passlock® reprogramming and CKP system variation learn procedures. After repairs, go to next step.
17. Using scan tool, clear DTCs. Start engine and operate vehicle under conditions required to set this DTC. If scan tool indicates this test ran and passed, go to next step. If scan tool does not indicate this test ran and passed, go to step 2.
18. Using scan tool, select CAPTURE INFO, REVIEW INFO function. If any undiagnosed DTCs are displayed, go to applicable DTC test. If no undiagnosed DTCs are displayed, system is okay.
Diagnostic Aids
An intermittent may be caused by a poor connection, rubbed-through wire insulation or a broken wire inside insulation. Inspect harness connectors for backed-out terminals, improper mating, broken locks, improperly formed or damaged terminals, poor terminal-to-wire connection, and
damaged harness.
With ignition on and engine off, HO2S 2 voltage on scan tool should gradually decrease to less than .15 volt indicating heater is operating properly. If voltage does not decrease as specified, disconnect HO2S 2 connector and connect a test light between HO2S 2 connector terminals "C" and "D" (engine harness side). If test light illuminates, replace HO2S 2. If test light does not illuminate, repair open in HO2S 2 heater ground circuit or HO2S 2 ignition feed circuit.
Using scan tool, monitor signal voltage while wiggling O2S 2 related connectors and wiring harness with a warm engine running at part throttle in closed loop. If a failure is induced, signal voltage will change from normal fluctuating voltage of greater than .6 volt and less than .3 volt, to a fixed voltage of about .45 volt. A change in voltage will assist in isolating location of fault. DO NOT solder HO2S wires.
© 2008 Mitchell Repair Information Co., LLC.
ROTORY-POWER
  • 9 POSTS
I have a 1999 Chevy Suburban K1500 5.7L with 173000 miles. I just replaced the starter & ignition switch. Got it running again, but am now showing a check engine light. On a couple of starts since installing the ignition switch the security light has also come on and stayed on, but it didn't affect the drivability. The truck hasn't been driven in the past 3 years and I can't remember if the check engine light was on or not before I stopped using it. I took it to AutoZone and had them pull the codes for it, but they couldn't tell me much beyond that. I also took it to the dealer and they wouldn't tell me anything except "$92 for an emissions diognostic", even though I had the codes in my hand. The codes that came up are as follows:
P0135 - HO2S 11 Heater Condition (Heated Oxygen Sensor Bank 1 Sensor 1)
P0155 - HO2S 21 Heater Condition (Heated Oxygen Sensor Bank 2 Sensor 1)
P0141 - HO2S 12 Heater Condition (Heated Oxygen Sensor Bank 1 Sensor 2)
P0161 - HO2S 22 Heater Condition (Heated Oxygen Sensor Bank 2 Sensor 2)
What is most likely to cause this problem?
-Bad O2 Sensors?
-Bad Cat.?
-Electrical/PCM Problems?
Just wondering where I should start and how to test? Thanks in advance for your time.
MXCANICHOLS
It is highly unlikely that all four sensors are bad. It is more likely that the fuse is blown. There is a 20amp fuse in the under hood fuse box. It is located along the drivers side fender aft in the underhood area. It should be labeled something like "Eng 1" If thats not blown, Check the grounding point on the lower front right side of the motor next to the harmonic balancer. There sould be a black battery type cable there. Those are the only two item that affect all 4 sensors other than the VCM- vehicle control module itself, but if that was failed, you would probably have other problems too
BIGTIMETRUCK
  • 9 POSTS
My check engine light is on, a diagnostic test states to replace Oxgen sensor 1 & 2 on both banks, as preventive maintenance I changed pre & Post cat on Both Banks,,,now the computer gave me multiple other codes,,, after installation.
Were the O2 sensors replaced or only the cats? Also, are the codes reflecting the O2 sensors again?
BIGTIMETRUCK
  • 9 POSTS
I replaced all 4 oxgen sensors, the i got all of these codes and i am lost.
P0300
P0154
P0155
P0161
P1153
P1336
any advice
The 1336 is my concern. Basically, it means the crankshaft position system variation values have not been stored in the PCM and the crankshaft position system variation learn procedure must be performed. That could be throwing off the sensors.
I can't be 100% sure, but I feel there is a problem with the PCM. You need to have a dealer check it.
BIGTIMETRUCK
  • 9 POSTS
is the PCM the Same as the ECM(computer)? I just want to make sure. I am reading you, correctly. and where is the Crank Postion Sensor located.
Yes
WILLISJR
Engine won't start, turns over but doesn't fire. Code reads circuit malfunction on bank 1 sensor 2 oxygen sensor. Changed out sensor and engine still will not start and code did not change. Thank you
RHALL77
  • 3,361 POSTS
did you check for fuel pressure and spark, and fuel injector pulse.
LEGITIMATE007
  • 5,121 POSTS
LEGITIMATE007
  • 5,121 POSTS
fuel pressure too
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
MERLIN2021
  • 17,250 POSTS
Try unplugging that sensor, will it start?
ANDETRAJ
My '97 Suburban seems to have no power. It has the 5.7L Vortec. I purchased it this way for little to nothing, thinking it was the transmission, and figured I would drive it until the transmission went completely out, then replace it, but it still has not gone. I have put nearly 10k miles on it since I purchased it. With the lack of power, it just took a while to get up to speed, so I just lived with the problem since it was my secondary vehicle and barely drove it. I am starting to drive it now more because its winter and 4x4. I am beginning to think it is not the transmission now. When I accelerate, it feels like there is nothing there. When I push on the gas pedal, the RPM needle does not "jump" like it should. I can get up to speed, but it takes a while if I nurse the pedal. It appears that the transmission is shifting smoothly, almost flawlessly, going through all of the gears, unless you push the pedal to the floor. I have to let off the gas for the trasmission to shift into the next gear at WOT when the RPM gets to the shifting point. Even at WOT, the RPM does not move nearly as fast as I think it should to get to the shifting point. There is no passing power, as I cannot push the pedal to the floor to get the proper response. I had not received any SES lights until the other day. It was cold, possibly under 10 degrees, and I was having a hard time getting up to speed. The engine shuttered at around 40-45 MPH and the SES light came on. I checked the codes with my OBDII tester and got these two codes: P0131 and P0151. Once this happened, the vehicle appeared more sluggish than normal. I could barely get past 45 MPH after this, with almost no engine response from the gas pedal. The codes were then cleared by me. After the vehicle was turned off and sat for a while, it returned back to its "normal" state where it still took some nursing to get up to 65, but it still got there. It has never returned to the 100% normal state. Some days are better than others. I received another error code just yesterday, which was just P0141, and not the other two. My friend was driving the vehicle at the time and said that he did not feel it shutter and that he believes the light just came on. When the vehicle is in park, I can push on the pedal and the RPM needle moves as it should (with maybe a little sputtering??) and it feels like there is proper air flow through the exhaust (according to a friend who is more car savy than me). I use Super Unleaded (ethanol) gasoline. I'm not sure if that information helps at all. What are some possible cures to the problem or problems I am having????
SERVICE WRITER
  • 9,123 POSTS
Sounds like you might have a couple problems going.
It is possible that both symptoms are related.
If it were mine, based on the O@ codes you have, I would replace ALL of them. Not uncommon to have them all weak, but some only weak enough to set the code. Because they are compared to each other by the pcm, the next weakest one will set a code after the first offender was replaced.
This may resolve all of it. Certainly should for the second part.
If problem(s) are still present, I would be looking at these:
What is the fuel pressure?
Unplug the MAF and drive it, does it change the symptoms?
Pull the plugs and pay attention to what cylinders they came out of. Do they look normal?
Have you changed the fuel filter?
ANDETRAJ
[quote:68dd59da7b="Service Writer"]Sounds like you might have a couple problems going.
Have you changed the fuel filter?[/quote:68dd59da7b]
I went for the cheapest thing first and I changed the fuel filter. When I pulled the filter and drained it into the snow, the snow turned black, not sure if thats normal or not. I could barely blow into the filter. When I did blow into it, it sounded like solid material came out, but could not tell for sure because whatever came out landed on a dirty concrete floor. After changing it, there was proper throttle response at any speed. It seemed like the vehicle had power, something its never had since I've owned it. I could press on the accellerator at 60mph and it would shift gears and accellerate quickly. After driving for about 20-30 miles, it almost returned to the way it was before I changed the filter. It lost proper throttle response, but is still not as bad as it was before changing the filter. Before changing the filter, if I would aggressively rev the engine, the RPM needle would immediately drop and kill the engine. If I would rev it slow, it would rev appropriately. The first time I started it after chaning the filter, I aggressively revved the engine and it did not hesitate and kill. Now, after driving it a while, if I aggressively rev the engine, it hesitates for approximately a half second, then revs normally, but does not kill like before. Thoughts?
SERVICE WRITER
  • 9,123 POSTS
Knowing the fuel pressure when the problem is happening would be good. Plugged fuel filter can damage a pump and it may be weakened. The filter was certainly on problem.
Since there still is an O2 code situation, The symptoms may be returning because of bad O2s.
Once the engine comes to temp and the O2s are activated, they may be reporting false data causing the pcm to make incorect adjustment to the A/F ratio.
DVICTORIA
  • 6 POSTS
Intermittant stalling at stop lights, lacks power on acelleration, get service eng code for O2 sensor after 15 mile drives. Replaced O2 sensor, fuel relay, fuel filter, plugs, wires, dist. cap and rotor, temp. sensor, set timing, checked fuel pressure - idles at 12 psi, no drastic changed when reving engine, pressure drops when shutting truck off. Checked for vaccum leaks - none. Cat. is not clogged. TBI sprays look good at idle and higher rpm. Some times will not start on 1st attempt. The TBI does spray fuel during this and the fuel pump is working, but engine does not start. Will start on second attempt. Thinking maybe it the Ing. module, coil, or ECM. Any suggestions?
The fuel pressure regulator or the fuel metering body is leaking
DVICTORIA
  • 6 POSTS
I was coming home from vacation and had to drive it 300 more miles when the problems started. I'll check out the regulator, but do you think that maybe the Oxy. sensor I replaced may be faulty or a problem with the ECM or Ign. Module?
DVICTORIA
  • 6 POSTS
Replaced EGR valve, it was not holding vacuum. This got me by emissions (barely). Problem turned out to be fuel pump. Although it was working, it wasn't working well enough to keep the vehicle running smoothly. Thanks to all who tried to help.
