[quote:7e3fb99aa2="Albino Martinez"]Engine Mechanical problem
2000 Chevy Tahoe V8 Two Wheel Drive Automatic 179000 miles
i just bought my 00 tahoe and got it lifted by the tensioners on the suspension, by the transmission and ever since i did this i noticed that oil has been leaking from where the engine and transmission meet. i have tried a stop leak on it and the problem still persists...any suggestions??[/quote:7e3fb99aa2]
A leak from that area is generally a rear main seal on the engine if it is engine oil that is leaking. If it is ATF then it is the front transmission seal.
In either case I would doubt that the lifting you did would cause either of those to leak.
Now if that vehicle has the oil cooler lines running up to the radiator then you may have a leak at the adapter that the oil filter and those lines go into. This adapter is notorious for the rubber oring to shrink and start leaking oil. Sometimes this oil runs down under the torque converter cover and drips out the drain hole or gets sprayed around by the moving torque converter which makes the oil seem like it is leaking everywhere in that general area.
The key is to inspect the adapter very carefully for oil around the base of where it meets the block.
May 4, 2010 at 11:00 AM
