2003 Chevy Tahoe abs and brake lights on dash
2003 CHEVROLET TAHOE
113,430 MILES • V8 • 4WD • AUTOMATIC
MASTER JAMES
when driving the front wheels hit a bump. the abs n brake lights on dash . the locks open and truck loses power.max up to 15mph. i put on diagnostic all good. i was told to check engine ground. looks good. please assist, dire straits. Thank you!
Jul 21, 2010 at 2:39 PM
HMAC300
  • 48,601 POSTS
have a pro scan it, your scanner might not be able to pick up ABS codes. you should check yoru dash and body grounds as well...... it could be a bad connection at the wheel or bad wire leading to the sensor.
Jul 21, 2010 at 3:14 PM
