check engine warning light
2003 CHEVROLET TAHOE
CLEARGLIDE
Engine Performance problem V8 Two Wheel Drive Automatic 40000 miles
Since it has turned cold, the check engine light remains on until the ambient temp rises to over about 36F. Sometimes it stays on days. The computer code indicated that the both cylinder banks are running too lean. Chevy dealer said the intake gaskets are leaking and need to be replaced to the tune of $650. Am I getting ripped off here??
Jan 7, 2010 at 8:09 AM
If they are leaking, no. But, are they sure that is the problem?
Jan 22, 2010 at 9:52 AM
BDOML
  • 4 POSTS
After you start the truck let it warm enough so there is no a lot of smoke out of the tailgate. Pour some water over the gaskets (just over the fuel rails) if you see a bunch of smoke start to come out of the tailpipe they are leaking.
Jan 6, 2018 at 3:42 AM
That is an interesting way to look for a vacuum leak. Some use smoke others carb spray the water and steam thing is new nice work.
Please feel free to help out whenever you are on the site :)
Jan 8, 2018 at 1:52 PM
