Hi tdecker85087 and TY for the donation
Check and test the distributor pick-up coil and air gap-also double check the cap and rotor contacts-if there's spark out of the coil-it should have spark at the plugs if cap and rotor good it has to make it out there to get to the plugs
DTC's
12
No Distributor pulses
13
Oxygen sensor
14
Coolant Temp sensor circuit
15
21
Throttle Position Sensor
22
23
Manifold Air temperature sensor
24
VSS (Vehicle Speed sensor)
25
32
EGR system
33
MAP sensor or MAF sensor depending on engine
34
35
Idle Air Control Valve
36
MAF Burn-off circuit
41
No Distributor pulses, cylinder select error
42
Electronic Spark Timing or Bypass fault
43
Electronic Spark Control fault
44
Lean exhaust
45
Rich exhaust
46
VATS system fault
51
PROM fault
52
CALPAK fault
53
System over-voltage
54
Fuel pump circuit
55
ECM fault
61
Oxygen sensor fault (degraded sensor)
Nov 20, 2018 at 5:37 PM
(Merged)
