1995 Chevy Truck Is it worth repairing
1995 CHEVROLET TRUCK
250,000 MILES • V8 • 4WD • AUTOMATIC
TYHARRISON
We have rebuilt the engine twice and put almost $5000 in the last 5 months, a rebilt tranmission, now when we just went for an oil change they found water in the differential fluid. The coolant is leaking from a spot in the engine we cannot find but towards the back.
Jan 14, 2009 at 6:55 PM
MIKE H R
  • 3,094 POSTS
The only one that can answer the question is it worth repairing, is you. I don't know what has been done to the truck or what the body is like. As far as water being in the diferental that could have happened if you went through a lot or deep water. With reference to the leak, check the hoses from the heater. They could have a pin hole in one or the clamps might need to be tightened or the hoses replaiced. The only other place woul;d be from the back of the intake manifold. Check the jhoses first to see if you can find a leak there.
Jan 16, 2009 at 11:45 AM
