There are a number of things that can cause this. So, let's start at the beginning as if you have not done anything.
Let's get the battery and alternator tested so that we can rule that out for good. Just replacing them at some point in the process does not mean that they are good parts so before we dive into test the rest of this, we need to rule that out for good.
Assuming they are both passing these tests then we most likely have a wiring issue where we have high resistance in the wiring, and it is not able to carry the load that the engine and electrical system needs at times of higher demand.
So, this means each of the wires going to the alternator needs to be load tested or resistance checked. I would not use a light bulb to load check them as we need to get a definitive measurement and trying to judge the brightness of a bulb is not definitive.
On this vehicle this testing is going to be easier because you only have two wires. So, we need to disconnect the wire from the starter and battery and then measure the resistance from the battery connection to the starter. Then from the starter to the alternator with it unhooked from the alternator as well.
Both readings should be less than a half ohm. If they are then we need to inspect the connections at each point on this circuit.
Then do the same for the circuit on the indicator. As you can see this indicator gets turned on based on a resistor so if there is resistance in the wire then that could falsely turn the light on.
Please let us know what you find or what questions you have. Thanks
Mar 30, 2022 at 9:07 AM
