My truck struggles up big hills and has trouble towing. I disconnected the MAF and the engine performed much better. I was able to pull my trailer up hill no problem. I am using 93 octane because it will knock under acceleration if I use 98 or 87. Also, idle is a little rough and when I release the accelerator the rpms do not drop. The truck will continue at the same speed fo a while and then slow down. Sometimes it will not slow down at all an I have to take it out of gear. I have replaced the cap, rotor, plugs, and wires. Thank you for your response.
Jun 13, 2010 at 9:06 AM
