93 Chey S10 ABS Brake fuse popping
1993 CHEVROLET TRUCK
S10 GUY
Hi !
I have a 93 Chevy S10 4x4 with 236,000 kms that is blowing the ABS brake fuse intermittly, seems when the truck warms up it will blow the fuse, i then lose my digital dash and auto transmission goes to default which i then have to shift manually using 1st and 2nd gear only i have no third or overdrive, sometimes it lasts a couple of days before it blows. Any ideas how to find this short circuit.
May 4, 2006 at 3:23 PM
LOSONE
  • 1,616 POSTS
Unplug the items associted with the fuse. I suspect you have a bad ABS module. If you loose ABS brakes they return to normal brakes.Let me know.
May 4, 2006 at 4:21 PM
