Computer problem
1998 Chrysler Intrepid 6 cyl Front Wheel Drive Automatic 249km miles
Hi there. as preventetive maitainance I wanted to do the timing belt as the car has 249,300 kms I changed the belt and made 100% sure that I did not disturb the timing once in position to have the three timing marks lined up. After reassembly a no start. I have check the cam sensor for voltage from the plug and there was 5 volts and when I back probed the plug at the cam sensor and hand cranked the cam sensor showed the needle on an anolg meter to jump. I then saw the crank sensor was coated in oil so I removed the plug , cleaned the plug and replaed the crank sensor with a new one, still no spark. There is supposed to be 12v at the green wire at each coil with key in the run position, nothing. All connections look good I have checked relays, bench tested them etc. I'm stumped. Any help would be greatly appreciated, Thank-you very much. Bill
May 20, 2009 at 8:02 PM
