I bought one engine at a salvage yard...the first one was cracked under the oil pan. Salvage yard replaced it. The second one started mixing oil and Antifreeze together...now I am stuck with that engine as the salvage will NOT change it...can this be repaired??? The heat tab are still in tacked on the engine...salvage yard says that I overheated it...I differ with him as I pulled over and turned the engine off when the needle started to rise...it did not get passed the 3/4 mark from mid-range. The BBB and BAR says that if I did overheated the engine that the heat tabs that the salvage yard put on the engine would have fallen off the engine....where do I go from here. I am retired Military with a Mom who is blind, a child with cerebral palsy...need help...Thanks
Sep 2, 2010 at 9:57 AM
