clutch not working
1976 TOYOTA COROLLA
55,000 MILES • 2.1L • 4 CYL • RWD • MANUAL
GREGORY COULING
  • 5 POSTS
I had the master cylinder and slave cylinder replaced for my clutch. It worked good but the next day went to drive and no clutch. The pedal was still firm but no clutch. This has happened several times. Can you help please?
Jun 19, 2017 at 8:34 PM
So you can put it in gear and lets out the clutch and nothing happens, or when you put it in gear it just grinds?
Pleas let me know,
Ken
Jun 22, 2017 at 10:41 AM
GREGORY COULING
  • 5 POSTS
When i try to put in gear it grinds. So start off in gear and after a while clutch seems to work better.
Jun 26, 2017 at 7:20 PM
It sounds like the clutch disc has fallen apart which causes the clutch material to get caught in the pressure plate so it is unable to release. To fix this the transmission must be removed.
Here is a guide that will show you what you are in for when doing the job.
https://www.2carpros.com/articles/how-to-replace-a-clutch
and
https://www.2carpros.com/articles/transmission-replacement-removal-manual
Jun 27, 2017 at 10:55 AM
GREGORY COULING
  • 5 POSTS
Thanks Ken your feedback is much appreciated. Will have transmission removed and will let you know the result, Cheers.
Jun 27, 2017 at 6:22 PM
Cheers!
Jun 27, 2017 at 7:22 PM
GREGORY COULING
  • 5 POSTS
Hi Ken had the clutch replaced and was ok for a week or so but now when i start up cold same problem. This is frustrating mate.
Jan 20, 2018 at 11:07 PM
KHLOW2008
  • 41,814 POSTS
Does repeatedly pumping the clutch pedal a few times before attempting to engage gears make any difference?
Jan 21, 2018 at 12:51 AM
It does sound like you have a problem with the clutch again. Did they replace the pilot bearing when they did the job?
https://www.2carpros.com/articles/pilot-bearing-replacement
Please let us know
Jan 21, 2018 at 12:48 PM
GREGORY COULING
  • 5 POSTS
Yes Ken replaced everything.
Jan 21, 2018 at 4:29 PM
Can you have someone press the clutch pedal down so you can watch the slave operation? Please take a video with your phone of it and upload it here to the site in your reply so I can see the movement.
Jan 22, 2018 at 6:01 PM
GREGORY COULING2
Ok Ken will get on it When they replaced the clutch master cylinder could they have installed the wrong one or installed it incorrectly. Cheers Greg.
Jan 22, 2018 at 6:34 PM
Yep, We will be able to tell if it is the clutch hydraulics or the mechanical part.
Jan 23, 2018 at 9:46 AM
GREGORY COULING
  • 5 POSTS
Hi Ken. The clutch must have a mind of it`s own. Now after a few months it has fixed itself and no problems. It is amazing and i cannot fathom how is this so, Cheers.
Mar 9, 2018 at 7:02 PM
Hmm, maybe it had an air bubble or a piece of the clutch disc come off and now has cleared the unit allowing it to work again.
Mar 10, 2018 at 10:52 AM
