Code p1652, Powertrain induced chassis pitch output circuit?
1996 BUICK REGAL
193,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
CHRISTINE S.12772
I have my car listed above, is at the shop. This is the code that came up. I have 4 codes actually, but this is one of them. I was told that depending on what they find out that this job could end up being thousands upon thousands of dollars, is this true?
Jul 19, 2023 at 8:19 AM
No, you could fix this problem yourself if you want to. The PCM is probably the issue, you can get a preprogrammed unit by searching Google or Ebay. But I would check all the fuses with the key on.
This guide can help:
The code P1652 is a generic diagnostic trouble code (DTC) that indicates a fault in the powertrain control module (PCM) communication circuit.
Jul 20, 2023 at 11:37 AM
