Now the car will not start? Code p0355
2006 CHEVROLET EQUINOX
130,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
PRRYPERRYS
  • 150 POSTS
I had Code p0355. I changed the crankshaft sensor. Now the car will not start. I don't know if it's something else. I turned the key I heard nothing, no click, no turning, absolutely nothing at all. Lights and radio come on. But when I turn the key absolutely nothing no clicks no turning nothing at all.
May 17, 2023 at 4:11 AM
It sounds like the starter has gone bad or you have a bad connection at the battery, here are two guides to help us see what's going on and I have included how to change the starter out in case you need it. Also, I would remove the new sensor to see if it is too long and contacting the crankshaft.
https://www.2carpros.com/articles/starter-not-working-repair
and
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
May 17, 2023 at 10:52 AM
PRRYPERRYS
  • 150 POSTS
Hey, my friend, I tried everything you said, the car still won't start. I forgot to tell you. I have an engine light on with a lock on it Thank the code said anti-theft lock.
May 21, 2023 at 8:07 PM
PRRYPERRYS
  • 150 POSTS
Not sure but I think that means I'm locked out of the car. When I turn the key I get nothing still.
May 21, 2023 at 8:08 PM
Let's run the codes to see what comes up. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Please go over these guides and get back to us.
May 22, 2023 at 11:25 AM
PRRYPERRYS
  • 150 POSTS
Hey, my friend, hope all is well finally have a chance to read the code here's what I got.
Jun 5, 2023 at 1:36 AM
PRRYPERRYS
  • 150 POSTS
Supplementary Inflatable restraints, Anti-lock brake system, electric power steering.
Jun 5, 2023 at 1:43 AM
What are the code numbers please?
Jun 6, 2023 at 7:33 AM
PRRYPERRYS
  • 150 POSTS
Good morning my friend, it will not let me. Read a code when I plug up the scanner all the dashboard lights start blinking really fast and it makes a ticking noise and then all the. Lights go out. However, I did see an engine light with a lock on. It never seen that before like I'm locked out of something I don't know.
Jun 7, 2023 at 3:50 AM
It sounds like the battery is dead. This guide can help confirm the issue:
Jun 7, 2023 at 11:35 AM
PRRYPERRYS
  • 150 POSTS
Hey, my friend, the battery was completely drained. thank you I fully charged it. Car still will not start. It will not let me read code it keeps saying error. I noticed a light on the dashboard. It's a car with a lock on it never seen that before. Car did not have this issue until my friend changed the full head gasket set and crank shaft sensor.
Jun 10, 2023 at 12:44 AM
PRRYPERRYS
  • 150 POSTS
How do I reset the automatic security system?
Jun 10, 2023 at 12:46 AM
PRRYPERRYS
  • 150 POSTS
Hey, my friend hope all is well I don't know why I keep listening to my friend at home I know they mean well. So, I upgraded my scanner battery was dead as you said so I upgrade scanner for better results here are the codes that I got Would not let me upload picture #1.body control module fault 21, # 2 supplemental inflatable restraint fault 1 # 3 anti-lock brake system fault 1 # 4 electric steering fault 1.
Jun 10, 2023 at 12:27 PM
The BCM can cause all of the problems you are having but I would check the fuses first. Here is the location and how to change the BCM out. Check out the images (below). Please let us know what happens.
Jun 11, 2023 at 11:47 AM
PRRYPERRYS
  • 150 POSTS
Hey Ken, I hope all is well. I will be getting to the car next week. I've been working my butt off. I will follow up with you after I check the fuses. Thank you my friend have an awesome day, talk soon.
Jun 21, 2023 at 2:07 PM
Yep yep!, let me know how it goes.
Jun 23, 2023 at 9:44 AM
PRRYPERRYS
  • 150 POSTS
Good morning, Ken, my friend, I hope all is well. fuses look good I will order a BCM I understand how to put it in but I'm not too sure about programming. I will keep you informed. thank you. Kenny
Jul 3, 2023 at 1:45 AM
Sounds good, have a nice 4th and let me know how it goes.
Jul 3, 2023 at 1:45 PM
PRRYPERRYS
  • 150 POSTS
I will my friend, thank you, have a nice fourth stay blessed.
Jul 3, 2023 at 1:54 PM
PRRYPERRYS
  • 150 POSTS
Good morning, my friend hope all is well. I just changed the BCM about twenty minutes ago car is still doing same thing will not start is there a relearn or program or maybe I missed a fuse in checking. then I only checked the one under hood could not get down to under dashboard on drive side due to my health.
Jul 10, 2023 at 5:09 AM
Was the BCM perprogramemd? Also is the security light flashing when you try to crank the engine over?
Jul 10, 2023 at 10:33 AM
PRRYPERRYS
  • 150 POSTS
Hey, my friend, I don't know if it was programmed. I bought it used from a parts store offline. Ebay and just put it in my car.
The security lockout light is blinking now. Before I changed BCM it was not blinking it was just on.
Jul 10, 2023 at 12:55 PM
It must be preprogrammed, or you will have this problem of the security lock out.
Jul 11, 2023 at 10:21 AM
PRRYPERRYS
  • 150 POSTS
How do I program it?
Jul 12, 2023 at 10:47 PM
You must send it in to be programmed or have a scanner capable of doing so from data collected from your old BCM.
Jul 13, 2023 at 10:00 AM
PRRYPERRYS
  • 150 POSTS
Okay, thank you.
Jul 13, 2023 at 11:59 PM
PRRYPERRYS
  • 150 POSTS
Hey, my friend, I hope all is well. I got the vehicle running, it was wiring negative wire burnt out on the BCM was replace car runs good, but after only driving 40 minutes this code came up P0420.
Aug 16, 2023 at 1:52 AM
Thanks for letting us know, we are here to help, please use 2CarPros anytime. Please post your new question here, you must be logged in:
Aug 16, 2023 at 11:54 AM
