Can I get the complete vacuum line diagram?
2005 SAAB 9-3
130,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • AUTOMATIC
MECHANICALGENIUS
  • 26 POSTS
I am finally getting around to finishing this project. What I am finding hard to come by is a vacuum line diagram. Car is a 2005 SAAB 9-3t Linear. VIN YS3FB49S751036861. I believe the engine is the 175 hp B207L. Thanks so very much for doing what ya'll do here.
The lines I am mostly interested in are the ones that attach to the center of the side of the engine facing front, just above and into the intake manifold. And, to line with curve on the end-it may go to one of the 2 ports (near bottom of one photo). (See pix)
Apr 19, 2025 at 8:56 PM
Yep, good call there, we don't have anything either as far as vacuum line diagrams, sorry. We should be able to figure out where the lines go though. The ports in the last picture, do they go to intake manifold vacuum? Some lines hold vacuum and others are just vent vaper lines FYI.
Apr 21, 2025 at 10:54 AM
MECHANICALGENIUS
  • 26 POSTS
Both enter the intake manifold. The lower one enters a bowl under and part of the manifold. One might be ported. I can remove the throttle body if need be. Thanks.
Apr 21, 2025 at 2:25 PM
One of the large ports should go to the brake booster, the other should go to the crankcase ventilation system. Can you pan out the image so I can see more of the engine?
Apr 22, 2025 at 10:45 AM
MECHANICALGENIUS
  • 26 POSTS
Completed. One port went to the air pump and one to the brake booster, and the other port went to the Evap system, indeed. Here is a link for a video on replacing all of the vacuum lines under the bonnet: https://youtu.be/_cZEeTJxdaE
Thanks for the help, ya'll.
Now to drain the fuel tank and put in some clean hi-octane gas as required, and to give 'er a go.
Apr 29, 2025 at 6:29 PM
Nice work, happy motoring! great video btw.
Apr 30, 2025 at 10:43 AM
