Coolant leak?
2014 BUICK ENCORE
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
BEETLEPUNK21
  • 124 POSTS
Hey Ken, I pulled off the front clip and I was able to get in there better and find out where the coolant leak is. I have attached a photo. It is this black piece that cracked. What is this piece that I need to replace?
Thank you very much for your help.
Feb 25, 2025 at 8:16 AM
This looks like the thermostat housing, here is how to change the part out which will fix the problem. Don't over tighten the mounting bolts.
80-inch pounds to tighten the bolts.
Feb 25, 2025 at 11:21 AM
BEETLEPUNK21
  • 124 POSTS
Thanks Ken!
Feb 26, 2025 at 6:14 AM
You are welcome, please use 2CarPros anytime we are here to help.
Feb 27, 2025 at 10:02 AM
BEETLEPUNK21
  • 124 POSTS
Hey Ken, are there any special procedures for refilling the coolant system?
I think I saw a video where a guy used a vacuum to suck all the air out before refilling it?
Feb 28, 2025 at 10:52 AM
I would not hold vacuum on the cooling system, just fill it normally. The system has an air bled hose so no worries there. Remove the cap and start the engine and keep filling until the engine is hot, then install the reservoir cap. Fill until at the correct level.
Feb 28, 2025 at 6:02 PM
BEETLEPUNK21
  • 124 POSTS
Awesome. Thanks Ken!
Mar 2, 2025 at 7:51 AM
You are welcome, we are here if you need us.
Mar 2, 2025 at 12:01 PM
