Cooling fans on and dash temperature reads 160?
2015 CHEVROLET SUBURBAN
189,000 MILES • V8 • 4WD • AUTOMATIC
UPMM019
  • 217 POSTS
I noticed today on a drive back home. about a 30-minute trip that about 3/4 way into it that I could hear the cooling fans running. I then noticed the temperature at 160 on the dash.
When I got home the fans were still running and the dash still reads at 160. The fans ran for about another 5-10 minutes after the vehicle was shut off.
I drove the vehicle this past weekend for four 45 minutes trips and didn't have any issues and the temperature was over 160 but below the 210 mark. I never heard the fans run.
So, I am not sure what the issue is or where to start to troubleshoot it.
Apr 16, 2024 at 8:47 AM
Thanks for the video. wait until the engine cools down and then check the coolant level inside the radiator. If that is okay, I would do a CAN scan to see if any codes are stored or pending. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
The temperature gauge and cooling fans are controlled by the PCM which if I had to guess is the problem. Here are the wiring diagrams so you can see how the system works. Also, I have included how to change the PCM out which you can get a pre-programmed unit by searching google or eBay. The PCM might just need an update from the dealer to help fix it. Check out the images (below). Please let us know what happens.
Apr 16, 2024 at 10:34 AM
UPMM019
  • 217 POSTS
So, you think the problem is the PCM or a temperature sensor? PCM seems like a real leap - I had figured it would be something more simplistic. I will check the coolant level, but I don't have access to a CAN tool. I have a cheap OBD II reader but that I only ever use if there is a check engine light. Mostly if check engine comes on this vehicle it's a o2 sensor error.
Apr 17, 2024 at 5:11 AM
I hear you, if the PCM thinks the engine is cold and it turns the fans on seems strange. We could try the coolant sensor to see if that fixes it, it could be a safety device.
Here is the sensor, also it could be the cluster as well, we might want to try a CAN scan to see if any other codes are stored. Here is the location of the sensor. Check out the images (below). Let us know how it goes.
Apr 17, 2024 at 9:56 AM
UPMM019
  • 217 POSTS
Did you mean to say that the PCM thinks the engine is warm and turns on the fans. If the engine is cold, I am not sure why the fans would come on. Is there any budget scanner you could recommend?
Apr 17, 2024 at 12:23 PM
UPMM019
  • 217 POSTS
I just checked the coolant level, and it appears to be normal. As soon as I start the vehicle the fans come on. I tried looking at the scan tool I have but didn't see anything on there that would tell me anything about the sensors.
Apr 17, 2024 at 5:51 PM
UPMM019
  • 217 POSTS
video
Apr 17, 2024 at 5:52 PM
UPMM019
  • 217 POSTS
I have the Autel OBD2 Scanner.
Apr 17, 2024 at 5:53 PM
Thanks for the video. Yep, that is not normal. The scanner you have will do engine codes only. You will need to upgrade the scanner to one of the more capable units or have a shop scan it for you. To me it sounds like an update for the PCM could fix it, but we will learn more once the CAN scan has been run.
Apr 18, 2024 at 10:07 AM
UPMM019
  • 217 POSTS
Replaced the thermostat and temperature sensor..... Issue is resolved.
Fans run when expected and dash temp now reads the range from cold to 210.
I didn't do a CAN scan since I didn't have the scanner for doing so.
Apr 24, 2024 at 7:21 AM
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Apr 24, 2024 at 9:41 AM
