Cranks but will not start?
2012 DODGE CHARGER
1,110,000 MILES • 5.7L • V8 • AUTOMATIC
KAYTHEQUEEN
I push the button and try to start it as normal. It cranks and won't start but acts as though it wants to start.
Aug 26, 2023 at 1:08 AM
It sounds like the fuel pump is going out, will the engine run on starting fluid? If so, we should run the codes and if none comes up let's do a fuel pressure test. Also make sure the tank has gas in it.
and
https://www.2carpros.com/articles/car-not-running-advanced
and
Check out the images (below). Let us know what happens and please upload a video of the engine cranking over so I can tell if the engine is hurt or not. Here is how to change the fuel pump out in case you need it.
Aug 26, 2023 at 1:31 PM
