No fuel pressure at fuel rail. The fuel pump does not run. Less than 7 volts to fuel pump (battery voltage 12.4). Jumped terminal 87 to 30 and read battery voltage at connector to fuel pump. I bench tested the PCM relay and fuel pump relay. Relays are okay. Checked terminals for PCM relay at relay base with my logic probe. Signal at all terminals. I checked the terminals for fuel pump relay with my logic probe. I found no signal at relay terminal #85. It seems I am losing ground somewhere. I have not traced the wire from terminal 85 at relay base back toward the PCM. I a very basic wiring diagram from a Chilton manual that only shows the general layout with no specific details. I plan to check from fuel pump relay terminal 85 to PCM I(hopefully today, weather permitting) I would appreciate any helpful advise.
Mar 15, 2020 at 10:50 AM
