Cranks wont start
2004 ISUZU RODEO
126,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
BRIAN D RUMSEY
  • 13 POSTS
The vehicle cranks but wont start. I have replaced both cam sensor. The crankshaft sensor and battery. Per the computer I have 63psi fuel pressure. I can crank it over but wont start. Every now and then it will start for just a second, but wont stay running. I have tried starting fluid and still will not start. Timing belt was changed 20,000 miles ago. No codes in the computer. Cannot be sure about the security features. I have tried both keys and still no start. I have always said I am a pretty good mechanic, but this one is kicking my butt.
Aug 19, 2016 at 4:25 PM
BRIAN D RUMSEY
  • 13 POSTS
Also, I know it is not the chip in the key. I tried a non chipped key and it wont even turn over then.
Aug 19, 2016 at 6:00 PM
SATURNTECH9
  • 30,869 POSTS
Have you checked for spark yet?
Aug 19, 2016 at 7:46 PM
BRIAN D RUMSEY
  • 13 POSTS
Yes and it is hit and miss. When there is spark it starts right up. I have the ECM at a re-builder now having it checked.
Aug 20, 2016 at 8:02 PM
SATURNTECH9
  • 30,869 POSTS
Does your code reader show live data like engine rpm?
Aug 20, 2016 at 8:20 PM
BRIAN D RUMSEY
  • 13 POSTS
Yes and it does not show any rpm's while cranking. Which is why I decided to have computer checked after replacing the crankshaft sensor.
Aug 21, 2016 at 12:31 AM
SATURNTECH9
  • 30,869 POSTS
Alright let me know when you get the computer back and what they said about the computer.
Aug 21, 2016 at 8:01 AM
BRIAN D RUMSEY
  • 13 POSTS
Will do.
Aug 21, 2016 at 9:20 AM
RENEE L
  • 1,260 POSTS
Please let us know so it will help others
Aug 30, 2016 at 9:14 AM
BRIAN D RUMSEY
  • 13 POSTS
Computer was tested and the processor was bad. But since it is isuzu they can't rebuild it. I got another one online but I have not gotten the chip in the key programmed so I still can't start the car
Aug 30, 2016 at 10:45 AM
BRIAN D RUMSEY
  • 13 POSTS
Getting really frustrated
Aug 30, 2016 at 10:46 AM
RENEE L
  • 1,260 POSTS
Okay lets start over from the top here is a guide that will help you.
Let us know what you find
Aug 30, 2016 at 10:48 AM
SATURNTECH9
  • 30,869 POSTS
Are you sure the key has a chip?
Aug 30, 2016 at 10:13 PM
BRIAN D RUMSEY
  • 13 POSTS
Yes. It is chipped. Unfortunately
Aug 31, 2016 at 4:37 AM
SATURNTECH9
  • 30,869 POSTS
Some lock Smith's have the key programmers you should call around.
Aug 31, 2016 at 7:21 AM
BRIAN D RUMSEY
  • 13 POSTS
Have to wait till Friday and will be doing that.
Aug 31, 2016 at 1:46 PM
SATURNTECH9
  • 30,869 POSTS
Let us know how you make out.
Aug 31, 2016 at 7:22 PM
BRIAN D RUMSEY
  • 13 POSTS
ok new computer is back and programmed to the keys and checked out good. but still no spark at the plugs
Sep 12, 2016 at 5:35 PM
SATURNTECH9
  • 30,869 POSTS
Do you have a code reader that can read live data?So we can see if there is a rpm signal while cranking the engine?
Sep 12, 2016 at 7:38 PM
BRIAN D RUMSEY
  • 13 POSTS
no mine won't read rpms
Sep 13, 2016 at 5:27 AM
SATURNTECH9
  • 30,869 POSTS
Do you have any current codes ?
Sep 13, 2016 at 4:16 PM
BRIAN D RUMSEY
  • 13 POSTS
no. there are no codes in the computer. i have checked all fuses everything. new cam sensors new crank sensor new computer.
Sep 13, 2016 at 5:16 PM
Does the engine have compression?
here are some guides that will help you
and
Let us know what you find so it will help others
Sep 14, 2016 at 5:21 PM
BRIAN D RUMSEY
  • 13 POSTS
Ok compression is good. And i am getting about 280 to 300 rpm while engine is turning over. But i am still getting no spark from any of the coils
Sep 17, 2016 at 9:40 AM
It looks like its time to do a pin to pin check of the wring harness, must be a shorted/broken wiring somewhere plus you can check the power and grounds, here is a guide that will help you
Please let us know what you find so it will help others.
Best, Ken
Sep 17, 2016 at 6:48 PM
BUDDIE95
  • 5 POSTS
Hello everyone, I realise this is an oldish post. but, I have a 2004 3.5liter V6 petrol 5 speed rodeo. I have been having an issue where the engine will crank but not start. The problem was intermittent at first but became progressively worse until the engine would not starter all. I have now worked out that the problem is either the fuel pump or the fuel pump relay. I swapped the fuel pump relay with the horn relay and the engine started . Just have to see if the problem occurs again now to test the pump. And yes the horn still works. Hope this helps.
Jan 31, 2021 at 4:47 AM
This sounds like a fuel pump or the crankshaft angle sensor has gone out. When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Jan 31, 2021 at 11:25 AM
BUDDIE95
  • 5 POSTS
Hi Ken,
No can’t hear the pump. It did the same thing yesterday so I shorted out the two large terminals for the relay and there was no difference. Also when cranking there is no fuel pressure at the valve on the left side fuel rail. I will be pulling the old pump out tomorrow and replacing with new one.
Feb 2, 2021 at 4:24 AM
BUDDIE95
  • 5 POSTS
On another note, can anyone explain why I get very bad fuel economy from this engine? Roughly 6km per 1 liter. 2004 Holden Rodeo with 3.5 liter V6 petrol with 5 speed manual box.
Feb 2, 2021 at 4:27 AM
you will need to start a new question for the Holden, if you have power to the pump but no pressure you will need to change the pump out here are the instructions. Check out the diagrams (below). Let us know what happens and please upload pictures or videos of the problem.
Feb 3, 2021 at 11:01 AM
BUDDIE95
  • 5 POSTS
Thanks Ken. I have replaced the fuel pump and the engine starts with no problem at all. By the way, I didn't take the tank out, I just undid a couple of the nuts and bolts holding the tray on and then jacked up the tray which gave me ample room to remove and replace the pump assembly.
Feb 17, 2021 at 4:35 AM
