Turns over but it will not start
2000 KIA SEPHIA
14,545 MILES • 0.5L • 4 CYL • 2WD • AUTOMATIC
COUEY
Car will turn over but will not start. have already cleaned everything and I am pretty sure check all the ground wires all the fuses on wires. I replaced the fuel filter and fuel pump check the line getting gas have not checked the plugs yet or the O2 sensor could it be the crankshaft sensor? Thank you and have a blessed day.
Nov 4, 2016 at 5:00 AM
HMAC300
  • 48,601 POSTS
try resetting security system if the link I send does not work then check online for your car. also if this does not work scan for codes.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Nov 4, 2016 at 7:06 AM
RENEE L
  • 1,260 POSTS
Hi COUEY,
If you need to scan for codes here is a link to an article that features written step by step instructions and pictures explaining how to do the scan yourself, also I have included a link to our YouTube channel with a how to video on code scanning.
This is applicable even if your check engine light is not on.
Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com
https://youtu.be/YV3TRZwer8k
Once you have the codes please get back to us so that we can further assist you. We are always happy to help.
Thank you for visiting 2CarPros.com.
All the best,
Renee
Admin
Nov 4, 2016 at 4:12 PM
I would like to know if the engine has compression. Does to sounds the same when you turn the engine over?
Best, Ken
Nov 4, 2016 at 6:52 PM
