Crankshaft sensor does not fit ?
2007 JEEP LIBERTY
130,000 MILES • 3.6L • 6 CYL • 4WD • AUTOMATIC
PJM333
  • 30 POSTS
I tried replacing the crankshaft sensor I got from AutoZone. The sensor would not fit, figured it was wrong part, so I ordered from a different store. Same thing happened, the old one goes right back in. I am on my fourth sensor, but they do not fit. I compared old and new and they look identical. Any ideas what is wrong? Thanks
Mar 7, 2025 at 5:58 AM
Can you upload an image of the old and new crankshaft sensors so I can see? To be clear this is the sensor you are replacing, correct? Check out the images (below).
Mar 7, 2025 at 11:16 AM
PJM333
  • 30 POSTS
That is the correct sensor, and I will take a picture on my next attempt. Thanks!
Mar 7, 2025 at 1:39 PM
STEVE W.
  • 15,116 POSTS
What doesn't fit? Check the old one for the O ring, is it on it? Is it the O ring that blocks it from fitting? They tend to fit very tight as the ring has to compress, I generally apply a bit of silicone grease to the O-ring then rock it a bit to get it started.
Should take a Mopar 56044180AC or an NTK0395.
Mar 7, 2025 at 3:17 PM
PJM333
  • 30 POSTS
I am not sure why, first time changing this sensor. The old sensor has o ring and look identical to new sensor. Thank you for the grease suggestion, first time hearing this. Before I do any damage, I am asking, my first thought was to bang it in. Thanks again!
Mar 8, 2025 at 4:30 AM
PJM333
  • 30 POSTS
Greasing the sensor worked, still took a while but I got it in. Better safe than sorry, ignorance on my part but I learned something new. Thanks for everyone's help.
Mar 8, 2025 at 8:12 AM
STEVE W. is one of our best! Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Mar 8, 2025 at 10:21 AM
PJM333
  • 30 POSTS
Thanks again Ken L and Steve W.
Mar 8, 2025 at 10:22 AM
STEVE W.
  • 15,116 POSTS
You are welcome.
Mar 8, 2025 at 11:11 AM
