When driving up hill truck tries to shift into lower gear the engine revs high and shuts off
2005 CHEVROLET AVALANCHE
96,000 MILES • 5.8L • V8 • 4WD • AUTOMATIC
TTHURMAN
Cruise control is set, when going up hill the control tries to get a lower gear to maintain speed, when all of a sudden the engines RPM pegs to over 5K engine shuts down. I have to put it in neutral while moving to start engine. This issue never happens when cruise control is off. What can be done? Thanks
Dec 10, 2019 at 4:38 AM
Do you have a check engine light on? if so this guide can help us get the codes:
Even if the light is not on you should run the codes anyway. It sounds like to could be a clogged catalytic converter but to be sure this guide can help:
Dec 11, 2019 at 11:09 AM
TTHURMAN
First of all thanks for your response. There was no check engine light and no codes. Both CATS were replaced and working properly. Still have the same issue is there anything else?
Dec 13, 2019 at 6:44 AM
Okay it sounds like the throttle bore could needs service causing the truck to go into limp mode.here is a guide to help you perform the service:
Dec 13, 2019 at 11:30 AM
TTHURMAN
Throttle-actuator is clean and functioning. Could this be a communication problem between the cruise control and something in the transmission?
Dec 14, 2019 at 6:40 AM
It could be. To be sure lets do a CAN scan which is the future of automotive repair you can get a CAN scanner from Amazon for about $50.00. here is a video to show you how:
https://youtu.be/InIlnsjOVFA
I have seen the input shaft speed sensor cause this issue as well. Here is the location so you can check it out.
Dec 16, 2019 at 11:39 AM
