dashboard lights and speedo and ref counter goes off while I am driving
2004 OPEL CORSA
285,000 MILES • 1.8L • 4 CYL • MANUAL
LUUSFRIK
I am getting an issue. While I am driving the hole dashboard lose power or go off. Sometimes when I need to start the car and the dashboard lights don't go on the car won't start.
I don't have any idea what can be the problem?
Jan 25, 2014 at 1:44 AM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
the car wont start because the gauge cluster is part of the antitheft system. that cluster should be available after market or even from the dealer. also try ebay or amazon.
Jan 29, 2014 at 9:28 AM
Hello, I have seen were the ignition switch sometimes shorts out causing the problem you are describing. Can you access the rear of the switch when the problem occurs? Use a test light and a wiring diagram to check
https://www.2carpros.com/manuals.php
please let us know what you find :-)
Jan 29, 2014 at 9:48 AM
