Valve cover gasket replacement
1999 SUBARU LEGACY
258,000 MILES • 2.5L • 6 CYL • 4WD • AUTOMATIC
HAZARDOUSKUSH777
Hello, I have found out that my vehicle listed above (Outback model DOHC engine) is leaking oil through the valve cover cover gasket. I went out and bought the valve cover gasket from Napa. I got home and I took out the windshield washer reservoir and disconnected the battery. Then unplugged the wire from one spark plug and unscrewed it as well. Now since i do not know if I could/should put the new spark plug back in where I took out the old one before or after I replace the valve cover gasket? And if it is after then how do I replace it?
Dec 8, 2017 at 12:21 PM
It is a great idea to change the spark plugs when doing this job but be sure to use OEM factory replacements do not fall for aftermarket plugs it will make it run worse.
Here are two guides that will help you see what you are in for when doing the job:
https://www.2carpros.com/articles/how-to-change-spark-plugs
and
https://www.2carpros.com/articles/replace-valve-cover-gasket
Check out the diagrams (below).
Dec 9, 2017 at 8:45 PM
