e-brake light is always on. I checked the wheel cylinders. they looked fine. I lifted the rubber boots and one side shows a little brake fluid. I went to check the brake fluid level in the master cylinder and it appears to have brake fluid all over it. I read in the haynes manual that if I replace the master cylinder to have the dealer bleed the brake because of abs. Do I need to do that or can I just bleed them myself? If I can do it myself I plan to replace the wheel cylinder as well.
Dec 13, 2007 at 2:52 PM
