2002 Dodge Intrepid No Spark
2002 DODGE INTREPID
AUTO ALAN
Electrical problem
2002 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
2002 intrepid 2.7 V6 motor. No spark on 2 cylinders.
Can switch coils and spark plugs to different cylinders and will have spark with same coil and plugs. Cylinders that have no spark still have no spark with working coil and plug.
Apr 28, 2009 at 10:19 AM
Then there is no power getting to the coil pack. Make sure all wires going to the ecm are tight. Wiggle the harness to see if that makes a difference. Also, make sure there are no broken wires to the coil. If nothing is found, you will need to have the ecm checked.
Apr 29, 2009 at 1:24 PM
