1998 Dodge Stratus runs rough when in drive
1998 DODGE STRATUS
RWROOSTER
Engine Performance problem
1998 Dodge Stratus 4 cyl Front Wheel Drive
Runs fine at ideal but when you put it gear to drive runs rough.
Aug 10, 2010 at 2:23 PM
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Aug 10, 2010 at 3:24 PM
MULDOON
  • 79 POSTS
Check the top motor mounts, I replaced mine on 96 stratus what a difference, if you need any input let me know, Declan.
Sep 3, 2010 at 5:28 PM
