starter replacement and location?
1999 DODGE STRATUS
RADIO95
Electrical problem
1999 Dodge Stratus 4 cyl Front Wheel Drive Automatic
How do you remove the bottom bolt of the starter? what do I have to remove to get to it?
Mar 17, 2009 at 7:33 AM
JDL
  • 16,098 POSTS
This guide will help walk you through the repair with diagrams below for your car. https://www.2carpros.com/articles/how-to-replace-a-starter-motor
https://www.2carpros.com/forum/automotive_pictures/170934_1999_1.jpg
https://www.2carpros.com/forum/automotive_pictures/170934_19991_1.jpg
Mar 17, 2009 at 10:38 AM
2CP-ARCHIVES
  • 4,540 POSTS
The ignition fuel starter fuse blew about 2 weeks ago & now it has just blown again.
this is on a 99 stratus what could be the problem?
Aug 3, 2020 at 1:47 PM (Merged)
CARADIODOC
  • 34,308 POSTS
Without knowing the exact fuse, first look underneath near the oxygen sensor(s), depending on which engine you have, to see if a wiring harness fell down onto hot exhaust parts and a wire has melted through the insulation and is grounding out.
WILLIAMJ3RD
Is there an easy way to remove the starter from this car and how?
ZACKMAN
  • 4,202 POSTS
Remove the battery cables from the fuse box and strut tower. Remove 2 starter connectors and 2 mounting screws.
WILLIAMJ3RD
I was givien a partial answer to the starter removal but not what I was looking for and the answer to the hard start up question no answer at all. As requested I made a donation for quick answers.
WILLIAMJ3RD
Engine Mechanical problem
1999 Dodge Stratus 4 cyl Automatic 113000 miles
How to remove starter and what to do about hard start-ups in the mornings.
ZACKMAN
  • 4,202 POSTS
Starter is underneath, kind of sandwiched between the motor and transaxle. Remove battery cable from the fuse box and driver side strut tower, remove 2 starter connectors and 2 mounting screws.
BULOCK88
I had my starter replaced about a month ago and it is now blowing fuses, when i asked the mechanic why it was blowing he said he wasnt sure, but it had a blown fuse a month ago and when he fixed it the starter was starting rough, so he went ahead and replaced it. So, now a month and a half later I am having the same problem. It seems like this is a common problem with the stratus make. From what it looks like it is the wiring, does that sound right and how do i get to fixing it?
JDL
  • 16,098 POSTS
Welcome to the forum, which fuses are blowing, need fuse position and amp rating. Fuse 8--20 amp? Try unplugging the fuel pump relay, see if fuse still blows? How long since a tune-up?
BULOCK88
the fuse is a 20a and it is for the ignition. it was just in about a month in a half ago when they replaced the starter, had it tuned up as well.
2CP-ARCHIVES
  • 4,540 POSTS
Wondering why it keeps blowing the ignition fuel starter fuse.
each component on that circuit has to be disconnected to see if the fuse holds. if it does, then the tech needs to attach each component till the fuse blows again to determine the area of failure.
it could also be a wiring issue as well. it is not an easy process and it is time consuming
ICCULOUS79
would like to figure out how to remove the starter?
Aug 3, 2020 at 1:48 PM (Merged)
ZACKMAN
  • 4,202 POSTS
Remove negative battery cable from the left strut tower. Remove your air intake box. You may need to remove the transmission control module as well, but do not disconnect the wiring harness. Once those are out of the way, you will see the top mounting bolt. Remove it.
Raise vehicle. From under the vehicle, locate at remove electrical connectors from the starter. Then remove the bottom mounting bolt. Starter is removed from under the vehicle.
CANDYANN29
1997 Dodge Stratus 4 cyl Two Wheel Drive 193000 miles
I need 2 know how 2 remove a strater from a 1997 2.4 liter dodge stratus
BLUELIGHTNIN6
  • 16,542 POSTS
Disconnect the negative battery cable from the left strut tower. The ground cable is equipped with a insulator grommet which should be placed on the stud to prevent the negative battery cable from accidentally grounding.
Remove the air cleaner resonator.
Remove the 3 bolts attaching the Transmission Control Module (TCM). Do not disconnect the TCM wiring. Move the TCM to gain access to the upper starter mounting bolt.
Remove the upper starter mounting bolt.
Raise and safely support the vehicle.
Remove the positive battery cable nut and disconnect the cable from the starter.
Disconnect the push-on solenoid connector.
Remove the lower mounting bolt that attaches the starter to the transaxle.
Remove the starter from the vehicle.
JCOOKI877
How do I change a starter in a 97 stratus v6 2.5 and what do I have to closeness or take off to get to it?
Please help.
HMAC300
  • 48,601 POSTS
Remove negative cable from battery to start and you will need to jack the car up here is a guide for that and to change the starter out along with diagrams (below) on how to do the job on your car.
and
Cheers
how do i take a starter out of a 97 dodge stratus sedan 2.4 litter automatic it has 12,000 miles on it
E40WATER12
  • 522 POSTS
All I can say its a real Pain, I would recommend getting a Haynes manual for reference.
FREDBUD
How to remove starter and replace
ZACKMAN
  • 4,202 POSTS
1. Detach negative battery cable from the ground stud on the left shock tower.
2. Remove air cleaner assembly.
3. Remove Transmission Control Module and move it out of the way. DO NOT remove the TCM connector.
4. You should be able to see the starter and the top mounting bolt. Remove it.
5. Raise the vehicle.
6. Remove wires from starter terminals.
7. Support the starter motor, and loosen and remove the bottom mounting bolt.
8. Withdraw starter from engine.
Install is reverse.
TOTERS1
how do you remove and replace the starter
BLUELIGHTNIN6
  • 16,542 POSTS
REMOVAL: Disconnect the negative battery cable from the left strut tower. The ground cable is equipped with a insulator grommet which should be placed on the stud to prevent the negative battery cable from accidentally grounding. Remove the air cleaner resonator. Remove the 3 bolts attaching the Transmission Control Module (TCM). Do not disconnect the TCM wiring. Move the TCM to gain access to the upper starter mounting bolt. Remove the upper starter mounting bolt. Raise and safely support the vehicle. Remove the positive battery cable nut and disconnect the cable from the starter. Disconnect the push-on solenoid connector. Remove the lower mounting bolt that attaches the starter to the transaxle. Remove the starter from the vehicle. ((Starter motor wiring terminal connections- 2.4L engine))
https://www.2carpros.com/forum/automotive_pictures/261618_0900c15280089646_1.jpg
INSTALLATION: Install the starter onto the transaxle and the lower mounting bolt. Tighten the mounting bolts to 40 ft. lbs. (54 Nm). Before reconnecting the wiring to the starter solenoid, be sure to clean the wiring of any dirt or corrosion. Reconnect the positive battery cable to the solenoid post and tighten the retaining nut to 90 inch lbs. (10 Nm). Reconnect the push-on solenoid connector. Lower the vehicle. Reinstall the upper attaching bolt and torque to 40 ft. lbs. (54 Nm). Reinstall the TCM to its original location and install the mounting screws. Reinstall the air cleaner resonator. Reconnect the negative battery cable. Thanks for using 2CarPros.com!
SCOTT5MICHELLE
1996 Dodge Stratus 4 cyl Two Wheel Drive Automatic
how do I change the starter in a 1996 dodge stratus? Is it easy to get to?
ZACKMAN
  • 4,202 POSTS
It is fairly simple. As always, remove the cables from the battery.
1. Remove your air filter box and assembly.
2. Remove mounting bolts to your TCM (transmission control module), but do not remove the wiring harness. Move the unit out of the way.
3. Remove two top mounting bolts.
4. Jack the front of the car.
5. Remove wiring harness and connector from the starter solenoid.
6. Support the starter unit, and remove lower mounting bolt. Remove starter away from vehicle (bottom).
Installation is reversed.
