Driver door window switch/heated seat switch do not illuminate
2008 BUICK LUCERNE
120,000 MILES • V6 • 2WD • AUTOMATIC
MUNDO9287
  • 7 POSTS
The switches on my driver side door are functional, they just don't illuminate. I've replaced the window harness, but that didn't fix the problem. Any help is appreciated.
Thanks!
Jan 16, 2021 at 3:11 PM
We need to test the STGILLUM #8 fuse in the interior fuse panel. here is a guide to help with the fuse locations below:
Jan 17, 2021 at 6:25 PM
MUNDO9287
  • 7 POSTS
Thank you. I will report back in the morning with video.
Jan 17, 2021 at 6:28 PM
MUNDO9287
  • 7 POSTS
Hello. I attached a video to explain better.
Thank you again.
Jan 18, 2021 at 10:00 AM
thanks for the video. it is suppose to light up on both sides please replace the fuse lets see what happens.
Jan 18, 2021 at 6:31 PM
MUNDO9287
  • 7 POSTS
I replaced the fuse, no luck...
Jan 19, 2021 at 4:06 PM
Okay, it looks like the BCM is going out. to be sure lets do a CAN scan which is the future of automotive repair. you can get a CAN scanner from Amazon for about $50.00. here is a video to show you how:
https://youtu.be/InIlnsjOVFA
Here is how you can replace the BCM. Check out the diagrams (below). Please let us know what happens.
Jan 20, 2021 at 5:05 PM
MUNDO9287
  • 7 POSTS
Hello, I replaced my BCM and that's didn't fix the issue. What else could it be?
Mar 4, 2021 at 11:23 AM
I attached the wiring schematic for the power windows so I could get a good look at the driver's switch. Here is what I want you to try:
First, I need you to check the ground for the door module. If you look at pic 2 below, I circled it and its location. Confirm there is continuity to ground via the two black wires.
Take care and God Bless,
Mar 8, 2021 at 6:57 PM
MUNDO9287
  • 7 POSTS
Thank you! I will try this tomorrow and report back.
Mar 8, 2021 at 7:07 PM
You are very welcome. Let me know what you find or if you have other questions.
Mar 9, 2021 at 4:41 PM
MUNDO9287
  • 7 POSTS
I wasn't able to locate the ground wires unfortunately, too many blocking my view. I will try again tomorrow.
Mar 9, 2021 at 5:28 PM
No problem. Let me know what you find or if you have other questions.
Mar 10, 2021 at 4:33 PM
