Does this vehicle have an EGR vacuum solenoid?
2000 CHEVROLET S-10
195,000 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
JOKYTAKI99661
  • 9 POSTS
does the vehicle listed above w vin have an EGR vacuum solenoid and if so, where is the location? p1404 code came up i have replaced the EGR valve with a new one i disconnected battery still comes up. i unplugged the EGR valve erased code, turned off key plugged back in still same problem, so I was curious if there was secondary EGR vacuum solenoid. Pictured below is EGR vacuum solenoid AutoZone sold to me.
Apr 29, 2023 at 7:57 PM
I looked through two different professional manuals, and neither shows one for this vehicle. I checked VIN W and VIN X for the 4.3L and I even checked for a 2.2L 4-cylinder and nothing is listed.
Do you have the part number for what they sold you? If you do, could you let me know what it is?
Also, I attached a pic below. That is what you should have.
See pic below.
Apr 29, 2023 at 9:07 PM
JOKYTAKI99661
  • 9 POSTS
Duralast part #pv164. yes, the p1404 code appeared after I installed a new fuel pump with the new 4 pin flat connector came on after about 7 miles with new pump. The fuel pump is working perfectly, the gas gauge and all. Thank you for your response will be returning part.
Apr 29, 2023 at 9:12 PM
That's interesting. I'm not sure why the pump/connector would cause this. The code is specific to the EGR valve pintel not fully closing when commanded to do so.
Do me a favor. Take a look at the pics below. They are the diagnostics specific to the code you have. Also, pic 1 is the wiring schematic. Let me know if you are comfortable performing the tests.
See pics below.
Apr 29, 2023 at 9:58 PM
JOKYTAKI99661
  • 9 POSTS
Will try those test when have time. I hear hissing on my driver's side, will a bad EGR tube throw a p1404?
Apr 30, 2023 at 11:47 AM
The sound would come from the tube if it has a leak, but I don't feel it would set this code. The code indicates the EGR valve is remaining partially open when it is commanded closed.
Apr 30, 2023 at 6:26 PM
