washer motor not working
1997 CHEVROLET MALIBU
143,287 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
ROGERMM65
  • 50 POSTS
i cover daylight sensor lights work at start but radio light dims.
All new bulbs in front end of car, cleaned grounds, blinkers started acting up first then passenger high beam went. so I cleaned grounds and replaced front bulbs, cannot afford bulbs for back yet. Push the washer button nothing happens, turn wipers on push button when wipers stop they go again. any advice will be greatly welcomed.
Feb 27, 2019 at 10:13 AM
It looks like you have two different problems. we will handle the wiper issue on this post please start a new post of the blinker issue.
Lets start by checking for power at the wiper fuse. here is a guide and the wiper wiring diagrams so you can see how the system works:
Mar 4, 2019 at 11:00 AM
ROGERMM65
  • 50 POSTS
Fuses new, power to fuse good. if washer motor is bad could that cause problems? if so can i unhook it or is it used to complete another circuit?
Mar 4, 2019 at 4:52 PM
Yes, you can disconnect the motor and use this guide to check for power and ground of the circuit.
Please run down this guide and report back after you checked the power and grounds.
Mar 5, 2019 at 9:57 AM
ROGERMM65
  • 50 POSTS
Are there other circuits besides the headlights operating through daylight sensor?
Mar 8, 2019 at 9:16 AM
Are we working on the windshield washer still or?
Mar 9, 2019 at 12:46 PM
ROGERMM65
  • 50 POSTS
No i am trying to figure out daylight sensor. does the daylight sensor control anything besides the headlights? and is it okay to cover it with tape?
Mar 9, 2019 at 2:09 PM
What happens with the washer motor?
Please post your new question here, you must be logged in.
Mar 11, 2019 at 9:44 AM
ROGERMM65
  • 50 POSTS
Washer pump no good, if i leave it unplugged will that stop anything else from working?
Mar 11, 2019 at 6:01 PM
ROGERMM65
  • 50 POSTS
Thanks for your knowledge and the t-shirt Ken.
Mar 11, 2019 at 6:04 PM
You can leave it unplugged no problems. You are welcome for the shirt. Use 2CarPros anytime, we are here to help. Please tell a friend.
Mar 12, 2019 at 10:20 AM
ROGERMM65
  • 50 POSTS
thanks again ,,,,, ill post yall on facebook
Mar 12, 2019 at 12:27 PM
