does the fuse only fail when the engine is started or as soon as it is replaced? If it happens after starting, remove the alternator and have it bench-tested. There could be an issue with the voltage regulator allowing too much power to be supplied to the battery.
I attached the wiring schematic for the charging circuit below. I circled the fuse I believe you are referring to. If that is incorrect, let me know.
Also, if the fuse fails as soon as it is installed, disconnect the connector at the alternator to see if it still blows when a new one is installed. If it doesn't, chances are we either have a short at the alternator connection or internally in the alternator
Take care and let me know what you find.
See pic below.
Sep 25, 2022 at 8:45 PM
