Engine swap question
1979 CADILLAC SEVILLE
30,000 MILES • 5.7L • V8 • FWD • AUTOMATIC
PIATKOWSKI000
  • 64 POSTS
Hello. Will the engine from 1977 Cadillac Seville 5,7 Gas will fit to 1979 Cadillac Seville or do I have trouble with this change? Both cars had the same 5.7 V8 engine. Someone made changes in my car listed above and took off all fuel injectors system, exhaust system and put carburetor in this car. I would like to bring back car to original shape. I have all original fuel injectors and electric wires in my second 1977 Seville. Do I have trouble with this change or is it should fit? I will be very very thankful for help. I am from Poland so sorry for my english. Thank You.
Jan 3, 2017 at 2:02 PM
STEVE W.
  • 15,113 POSTS
Same parts and injection hardware for both years, GM did not change much until 1980 when the newer smaller version came out (with that ugly lump of a trunk).
That is actually an Oldsmobile engine in both. Cadillac did not have a "small" engine for the car so they simply "borrowed" from the sister company and dressed it as theirs.
1977 to 1979 also have disc brakes and better ride than the 1975/1976 versions.
You have a big job ahead of you, good luck.
Nice cars, wish they still looked that good in my area, around here those would be scrap by now.
Your English is better than many of the people I talk to daily, and they were born speaking "english".
Jan 3, 2017 at 7:43 PM
PIATKOWSKI000
  • 64 POSTS
Thank You very much for the quick answer. So is it possible to change engines and still have good riding car? I would like to keep this 19 79 Seville in original shape because it is limited version 1 of 200. I have all new fuel injectors in 1977 Seville engine and it sounds well and better than engine from 1979. Thank you.
Jan 4, 2017 at 5:54 AM
PIATKOWSKI000
  • 64 POSTS
Will all electric wires fit too ? Thank you very much.
Jan 4, 2017 at 5:59 AM
STEVE W.
  • 15,113 POSTS
Everything should be a direct bolt on. Engines are the same, wiring should be all the same.
Jan 4, 2017 at 6:18 AM
PIATKOWSKI000
  • 64 POSTS
Thank you very very much. Best regards from Poland!
Jan 4, 2017 at 6:27 AM
STEVE W.
  • 15,113 POSTS
You are very welcome. Thank you for using 2CarPros.com. Please return with any auto related questions, we are here to help.
Jan 4, 2017 at 9:44 AM
RENEE L
  • 1,260 POSTS
Great information Steve W.
Jan 4, 2017 at 2:10 PM
PIATKOWSKI000
  • 64 POSTS
Hello again Steve . I have one more question about my problem with 77 and 79 Cadillacs Seville. In 79 Seville they take off all wires from fuel injection and put new edelbrock carburetor. My question is: If I would like to change engine from 77 to 79 seville do I have to make any modification with dashboard wires or all wires from engine and fuel injection are ending in engine bay? Is dashboard wires are separate from the engine and fuel injection wires in engine bay? I hope You understand me. It's really important. I hope You can help me. Thank You very very much.
Jan 9, 2017 at 6:34 AM
STEVE W.
  • 15,113 POSTS
There is a large connector that joins the interior wiring to the engine and front end wiring mounted at the firewall below the steering shaft. You should be able to take the entire front harness from the 77 and plug it in and get all the wiring they removed back.
There will be a bolt that holds the two big connectors together.
Jan 9, 2017 at 9:53 AM
STEVE W.
  • 15,113 POSTS
These are similar to the connector except yours will have more wires.
Jan 9, 2017 at 2:41 PM
PIATKOWSKI000
  • 64 POSTS
Thank You very very much for help. Now I know much more. I hope everything will be ok and car will still be riding. The engine from 77 sounds much better than engine from 79. I like to keep old cars in original shape. Thank You very much again for help.
Jan 9, 2017 at 4:50 PM
Please use 2CarPros anytime, we are here to help and tell a friend.
Best, Ken
Jan 14, 2017 at 11:23 PM
