Engine bogs and shuts off sometimes?
1981 JEEP CJ7
200,000 MILES • 4.2L • 6 CYL • 4WD • MANUAL
Engine idles fine, but when you give it gas it bogs down and shuts off sometimes. Ran it a few minutes the exhaust manifold got cherry red. Any suggestions?
Sep 29, 2025 at 5:24 AM
BLACKOP555
  • 10,386 POSTS
Sounds lean. Try adding extra fuel. Or checking for vacuum leaks around intake with it running. Revs up with brake clean you found a leak. If no vac leaks I would check fuel supply.
Sep 29, 2025 at 6:01 PM
Does this car have a catalytic converter? it might be clogged or the engine is running rich, can you please remove the spark plugs and upload an image here so I can see? In the meantime please go over this guide:
https://www.2carpros.com/articles/why-an-automotive-engine-will-run-rich
Oct 1, 2025 at 9:08 AM
