It sounds like a lifter. By chance, did you have the camshafts removed? Also, I need to know the engine size.
The sound, as I mentioned, sounds like a mechanical issue with a lifter or rocker arm. That's why I asked about the camshaft. As far as timing, other than the noise, it seems to run smoothly which would indicate the timing is correct. So, let me know the engine size, if anything was done with the camshafts, and (don't laugh) if you had any issues with the exhaust manifold install. Believe it or not, a leak can sound very similar to this, but my first thought is mechanical.
Nov 16, 2022 at 8:42 PM
