Engine knocking In gear three?
2017 MAZDA 3
150,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
MOZAFAR1988
  • 6 POSTS
During driving, when speed gear changes from 2 to 3 and 4 to 3, both manual and automatic drive mode, engine has knock which shake the engine and car during driving. I want to know how to solve it.
Dec 26, 2024 at 5:31 AM
It sounds like the knock can be an engine misfire; do you have a check engine light on? If so, let's run the codes to see which codes are stored which can be an ignition coil or spark plug issue.
Here is a guide to help us go over engine knocking and what will cause it:
https://www.2carpros.com/articles/understanding-and-repairing-engine-knocking-noise-an-in-depth-guide
Can you please shoot a quick video with your phone so I can hear the noise? That way I can tell for sure what's going on. Please go over these guides and get back to us.
Dec 26, 2024 at 1:58 PM
MOZAFAR1988
  • 6 POSTS
Video while engine just working or during driving?
Engine light is on and has error code I think 0U014 is error.
Dec 28, 2024 at 4:38 AM
MOZAFAR1988
  • 6 POSTS
Actually its Shocking knock during driving and gear shifting 2 to 3 and 4 to 3.
Dec 28, 2024 at 8:06 AM
MOZAFAR1988
  • 6 POSTS
Engine working normal driving and shifting gear make shock during drive.
Dec 28, 2024 at 8:49 AM
It seems like it is running okay, thanks for the video. Have you tried new spark plugs and ignition coils? Also, the code does not make sense. Do you have a p0301 style code?
Dec 28, 2024 at 10:33 AM
MOZAFAR1988
  • 6 POSTS
Spark plugs were replaced recently, I will check again today and send you engine error code screen shot, it may help more. I think it can be from transmission gear box system. Thanks for support.
Dec 29, 2024 at 1:56 AM
Yes, errors codes can help us. Also, I would replace the ignition coils and make sure none of the spark plugs are cracked, which is common.
Dec 29, 2024 at 12:52 PM
