go in reverse sometimes it stalls?
1998 CHEVROLET BLAZER
192,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
BRIBRI4275
  • 24 POSTS
When I first start it then go in reverse sometimes it stalls. Also, when I put it into drive it doesn't go past 2,000 RPMs and it seems to lose power. What could cause this?
Sep 30, 2024 at 1:30 AM
It seems like you may have two problems but let's handle the stalling in this thread. I would first replace the IAC valve which should helps with the stalling. Here is a guide to go over as well and I have included two guides that can help as well.
https://www.2carpros.com/articles/stall-at-idle
And this guide can help get any codes that can lead us to the problem:
Check out the images (below). Please upload pictures or videos in your response of any problems so we can see what to help you with. I would service (clean) the throttle bore and IAC passages as well.
Oct 1, 2024 at 10:30 AM
