Can I get the engine wiring diagram for the PCM?
1998 DODGE DAKOTA
100,000 MILES • 5.2L • V8 • 4WD • AUTOMATIC
DARIN EMMETT
  • 10 POSTS
Hello, I am looking for the engine wiring diagram for the PCM for the 5-volt power supply. The engine runs and then periodically shuts off losing 5-volt supply.
Jan 27, 2024 at 6:57 AM
Sounds good, here is a guide to help check the wiring and the engine wiring diagrams as you have requested:
The five-volt reference can be disrupted by a shorted sensor, when you lose the reference, I would start unplugging sensors to see if it comes back. Check out the images (below). Let us know if you need anything else.
Jan 27, 2024 at 12:04 PM
DARIN EMMETT
  • 10 POSTS
Thank you for the schematics. Still having the same issue. Engine dies, no 5-volt ref and no buss message on odometer. If the connectors to the PCM are wiggled power comes back. PCM has been replaced with a rebuilt. I'm thinking the new PCM is bad as well? Unplugging sensors has no effect. All pins and connections at the connectors look good as well.
Jan 29, 2024 at 4:15 AM
DARIN EMMETT
  • 10 POSTS
Thank you for the schematics. Still having the same issue. The engine shuts off, no 5-volt ref and no buss message on odometer. If the connectors to the PCM are wiggled power comes back. PCM has been replaced with a rebuilt. I'm thinking the new PCM is bad as well? Unplugging sensors has no effect. All pins and connections at the connectors look good as well.
Jan 29, 2024 at 6:32 AM
I have seen an instrument cluster cause this issue as well. Can you try unplugging it to see if the 5 volts comes back? Also, it does sound slie the new PCM is bad as well, did it have the same problem with the old PCM?
Jan 29, 2024 at 10:14 AM
DARIN EMMETT
  • 10 POSTS
Yes same problem with the old PCM.
Jan 29, 2024 at 10:17 AM
DARIN EMMETT
  • 10 POSTS
I can try unplugging the instrument cluster and let it run to see if it shuts off if the engine will run that way??
Jan 29, 2024 at 10:20 AM
It might, let's give it a try. let me know what happens.
Jan 30, 2024 at 9:59 AM
anything?
May 10, 2024 at 2:24 PM
