Error codes P0447, P0643, P0102 and P0340, after Oil leak?
2015 NISSAN VERSA
192,000 MILES • 1.6L • 2WD • MANUAL
BRETTMCNUTT
Oil spilled all over the engine after the oil cap was left off on the car listed above Note. And now it's losing power when driven.
Originally when I put on the scanner, I had codes of: P0447, P0643, P0102 and P0340. I replaced the air filter and cleaned MAF sensor, which fixed P0643 and P0102.
But after driving it to test it I noticed car losing power again. Put it back on the scanner and now I have codes P0447, P0340, P1078 and P2135.
Took one cam sensor out and noticed it was a bit fried, so I replaced it, but I am still getting the same error codes.
Jul 26, 2023 at 11:48 AM
Is there an electrical connector not connected? Or I think the system was turned on with the sensor disconnected during the job, I would try clearing the codes to see what happens, and make sure everything was plugged back in.
https://youtu.be/ahK_eucFi-k
P0447 - Evaporative Emission Control System Vent Control Circuit Open:
P0643 - Sensor Reference Voltage "A" Circuit High:
P0102 - Mass or Volume Air Flow "A" Circuit Low:
P0340 - Camshaft Position Sensor Circuit Malfunction:
It sounds like you may have had a voltage surge which took out the PCM which happens, you can get a preprogrammed unit by searching Google or Ebay.
Here is how to change the PCM out in case you need it. Also, I have seen the IPDM cause this issue as well, but to confirm the issue with the IPDM you will need to use a CAN scanner, you can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Jul 27, 2023 at 5:02 PM
